WTT - Pair of 1 3/8ths Winfield Model 5H carbs for...
Topic author - Posts: 170
- First Name: Douglas
- Last Name: Ogden
well, what I really need is a useable A crank converted T engine (long block) year not important...lets make a deal...or Looking for a complete runnable Model N ~ 1 3/4" or so or $1,200 for the pair.
- First Name: Kevin
- Last Name: Pharis
Re: WTT - Pair of 1 3/8ths Winfield Model 5H carbs for...
As I recall... the model “N” carbs were only produced in 2”+ barrel sizes...
I will dig up my catalog to confirm
- First Name: Kevin
- Last Name: Pharis
Correction... looks like it was 1-3/4”, 1-7/8”, and 2”
- Last Name: Ogden
Thank you for the information Kevin, did not know that!
- First Name: Mike
- Last Name: Penserini
- * REQUIRED* Type and Year of Model Ts owned: 27 roadster pickup, brass speedster, Mercury # 253 B, Mercury # 1070, Faultless "Hoosier" parts collection.
The Model N can be sleeved down, here is an early (not for sale) 2 inch N sleeved down to 1 1/2 inch.
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Have a complete short block "Stoker" Skat Crank ready for assembly. Cross drilled, A rods, correct pistons and rings, flat top, (T bore to A rods). $5,000.00 you pick up and assemble at your leisure.
All the Best,
All the Best,
- First Name: Kevin
- Last Name: Pharis
Hey there Mike, thanks for showing that model N. What’s the story on the reducing sleeve...? Was it done to repair a broken throttle housing...?
Oh yeah, nice lookin velocity stack
- Last Name: Ogden
Thank you Hank, that is exactly what I am doing to myself right now with my current build. Hoping that someone has a long block and some other bits they finished 40 or 50 years back sitting in a corner, and a pair of 5H's are just what would make their collection a bit more complete and I can get a jump.
Henry K. Lee wrote: ↑Sun Aug 01, 2021 6:45 pmHave a complete short block "Stoker" Skat Crank ready for assembly. Cross drilled, A rods, correct pistons and rings, flat top, (T bore to A rods). $5,000.00 you pick up and assemble at your leisure.
All the Best,
- First Name: Jack
- Last Name: Tarlinton
- * REQUIRED* Type and Year of Model Ts owned: 1927 Cut off
If your trade is unsuccessful, I'm interested in buying one 5-H. Are either of yours operable?
Best regards
Jack
Best regards
Jack
- Last Name: Ogden
Good day Jack, hadn't planned on breaking up a pair, H's are rare as Winfield's go, and good pair is even more so.
Yes, these are in nice shape, barrels are tight with limited play, have all the little fiddly brass parts that are always beat up or gone, even have the float bowl caps.
Jack Tarlinton wrote: ↑Sun Aug 01, 2021 10:43 pmIf your trade is unsuccessful, I'm interested in buying one 5-H. Are either of yours operable?
Best regards
Jack
- First Name: Jack
Well, if you do end up stuck with the pair and get tempted to let one of them go, please let me know!
Thanks Douglas
Thanks Douglas
blauvelt wrote: ↑Tue Aug 03, 2021 10:52 amGood day Jack, hadn't planned on breaking up a pair, H's are rare as Winfield's go, and good pair is even more so.
Best regards
Jack
- Last Name: Ogden
Bumpity bump bump.
- Last Name: Ogden
Have a home for one, 600.00 for the other.
