Gaskets NEW Multiple sets ALL SOLD!
Tbird
Last Name: Bird
Post by Tbird » Wed Aug 04, 2021 1:48 pm
All these gaskets are new. They have been setting on shelf in storage. All plus shipping. Most of these can fit in a small envelope.
mikebird@lifeattheridge.net or 574-584-6744
#1 Valve Cover Gaskets (3) -$1 for all three
#2 U Joint Gaskets (4)- $.50 Each
#3 Cylinder Outlet Gasket (2) $.10 each
#4 Timing Gear Gasket 19-27 (1) $.50
#5 Timing Gear Gasket 09-18 (1) $.50
#6 Half Cover Gasket Timing gear (2) $.50 Each
#7 Cylinder Inlet Gasket (2) $.10 Each
#8 Crankcase pan lower gasket 12-24 (3) $2.00 Each
#9 Crankcase pan lower gasket 24-27 (3) $2.00 Each
#10 Cylinder valve cover gasket 1 piece 21-27 (2) $1.00 Each
#11 Magneto post gasket 09-25 (2) $.25 Each
#12 Transmission cover front felt gasket (1) $.50
#13 Transmission cover door gasket (3) $.50 Each
#14 Starter drive gaskets (4) $.25 Each
#15 Fan Pulley Gaskets 20-27 (3) $.25 Each
#16 Timing Gear side cover gasket 19-27 (2) $.25 Each
#17 Starter Mounting Gasket 19-27 (3) $.50 Each
#18 Generator Mounting Gasket 19-27 (1) $.25
#19 Drive shaft paper gaskets (3) $.25 Each
