Remy distributor $45.00 I'll pay shipping in USA or Canada.
The pot metal housing is toast. The cap looks good but has two small cracks. One at the notch and one 180°away. It fit the housing before it cracked and expanded. The rest of the parts look to be usable. The rotor has a small chunk broken out too.
The pot metal has seized in the bracket as well as the upper half of the shaft. As you can see, the lower part of the bracket has rust and pitting outside but the gear within which was covered with grease survived pretty well.
I'm not up to speed on this brand.
Remy Distributor for parts.
Topic author - Posts: 6815
- MTFCA Number: 1219
