FOR SALE: STEVENS FRONT AXLE TOOL FRAME
Topic author - Posts: 387
- First Name: Jack
- Last Name: Putnam
- MTFCA Number: 13833
- MTFCI Number: 13353
***For Sale: Steven"s Front Axle repair tool Frame. Reproduced in cast iron, as the original. It is used to repair the worn king pin holes in the front axle of the Model T. This is the frame only as you will need the reamers and inserts available elsewhere.
$275 plus $16 shipping in the USA. I will accept a check or PayPal friends at jputnam(at)wcoil(dot)com . Available now, I have few in stock and this may be the last batch. USA made in Ohio. Contact 419-three zero 6-three nine 66. Thanks for your support.
- First Name: Jack
- Last Name: Putnam
Re: FOR SALE: STEVENS FRONT AXLE TOOL FRAME
If you really want to fix the front axle, you will need this tool.
- Last Name: Hatch
- MTFCA Number: 49974
Back to the top
- First Name: Neil
- Last Name: Dobson
- * REQUIRED* Type and Year of Model Ts owned: 5
- MTFCA Number: 29351
Hello, could you let me know if this item is still available for sale.
Regards
Neil Dobson
Regards
Neil Dobson
- First Name: Jack
- Last Name: Putnam
only two remain in stock.
- Last Name: Whitchurch
- * REQUIRED* Type and Year of Model Ts owned: 1920 Touring, 1918 TT Truck, 1923 Roadster
- MTFCA Number: 51063
- MTFCI Number: 25503
Are these tools still available ?
Regards
Steve
Regards
Steve
- First Name: Jack
- Last Name: Putnam
Presently the Steven's front axle tool is out of stock. If I find there is sufficient interest I can do another run of them. JP 4/7/23
I would be interested ...
Would the price be about the same $275 ?
Please let me know if you do another run of this tool ..
Regards
Steve
Regards
Steve
- First Name: David
- Last Name: Ruedy
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Runabout
- MTFCA Number: 50076
I'd be interested, as well, at $275.
-David
-David
David - Yukon, OK
- Last Name: Hatch
Jack looking prices of the hub threading tool , maybe you should think about another run of them!
- Last Name: Wrenn
- MTFCA Number: 30701
- MTFCI Number: 24033
Add me to the list Jack!!
I would like one as well if you still have one
Scott
Scott
Jack, looks like there is demand!
Now, hopefully, foundry prices haven't been jacked up too badly!
NH Full Flow Float Valves
- First Name: Jack
- Last Name: Putnam
May have to give this project some serious thought.
- First Name: steven
- Last Name: davidson
- * REQUIRED* Type and Year of Model Ts owned: 1924 touring
- MTFCA Number: 51591
I already have one of Jack's Stevens tool frame. Along with Dan hatch's cutters and reamer it's just the thing for front axles. I'm confused if the interest is in the frame or the thread chaser. If the latter, I'd like on that list too.
SteveD;
The cutters and reamer you talk about, are those the ones that work with the Steven's tool frame ?
Regards
SteveW
Regards
SteveW
Thanks Tim and Steve for the information ...
Regards
Steve
Regards
Steve
