Spare Rim
Topic author - Posts: 28
- Last Name: Riggio
Spare Rim
Looking for a rim to use for a spare on my 1922 Touring. It's one of the things that was missing when I purchased the car. I'm on Long Island and to find one local might be best. I will travel if need be though.
- * REQUIRED* Type and Year of Model Ts owned: Speedster (1919 w 1926)
Re: Spare Rim
Not all rims are the same and need to match the fellow. Pictures of the one that includes the wheel clamps (head one and a bit of a side profile) might help ID it. Might try to contact Dennis in Burlington Conn https://mtfca.com/phpBB3/viewtopic.php? ... on#p124614
has 3 barns full of T stuff - may pick up some other things you didn't know you needed
- First Name: David
- Last Name: Menzies
- MTFCA Number: 27825
- Board Member Since: 2012
Re: Spare Rim
There were at least four rim manufactures, 3 inch, 3 1/2 inch, wood felloe, steel felloe, non demountable and demountable, Do you want to just carry around a rim for show or carry a complete spare with tire mounted?
- First Name: David
Re: Spare Rim
There are also a variety of Chevrolet rims that fit.
- Last Name: Hanlon
- MTFCA Number: 50191
Re: Spare Rim
Appears to be a Hayes wheel.
I have a few here in Ohio.
Re: Spare Rim
The mounted tyre is on a Hayes rim. That usually means any of the other Ford fixed lug rims will be suitable if another Hayes rim is not forthcoming.
The reverse swap, Hayes to Ford wheels, is not always on due to the 'foot' on the Hayes rim lugs not clearing the edge of the felloe.
