NEW 1926/27 Fordor Front Window Regulator Small Gear
henryford2
First Name: Joseph
Last Name: Andulics
MTFCA Number: 9766
Post by henryford2 » Wed Sep 22, 2021 12:25 pm
I water jet cut these specifically for my 1926 Fordor 4 hole front window regulator, they may fit others but I won't have a clue as to which. You may have to dress the teeth slight to make them burr free, but otherwise it's a very nice water jet cut part. Cut from .125 material as the original, they are NOT hardened so they may wear out in the next 40-50 years if that is an issue. This is not a "plug & play" replacement there is some "work" required to replace this gear. $25 for a pair postage paid in the CONUS. Please respond to jandulics@gmail.com
henryford2
First Name: Joseph
Last Name: Andulics
MTFCA Number: 9766
Re: NEW 1926/27 Fordor Front Window Regulator Small Gear
Post by henryford2 » Thu Sep 30, 2021 7:46 am
Back to the top, then back on the shelf
