NEED 2 HAYES DEMOUNTABLE 30 x 3 1/2 RIMS
Topic author - Posts: 26
- First Name: Anthony
- Last Name: Ventrice
- * REQUIRED* Type and Year of Model Ts owned: 1922 Ford model t touring
- Board Member Since: 2013
Hi everyone, looking for 2 very good rims....hopefully affordable.....I am going to Hershey and can pick them up from you if possible. I appreciate if you can help me out, I am trying to save up and need all new tires and want to do this for the spring. Thanks.
- First Name: Walt
- Last Name: Wise
- MTFCA Number: 12345
Re: NEED 2 HAYES DEMOUNTABLE 30 x 3 1/2 RIMS
Here is one on T-bay - no connection to listing whatsoever...
https://www.ebay.com/itm/133886296566?h ... J&LH_All=1
The same seller appears to have two more Ford rims which from the outside I think are identical...
- Last Name: Iaccino
- MTFCA Number: 17726
I just picked up a bunch of T and TT wheels and rims. I'll check if any are Hayes. I'll be set up in Hershey in Chocolate Annex C4Y 34-37. T rims and whels are 30 x 3 1/2, TT are the earlier 23" wheels and rims.
Frank
Frank
- * REQUIRED* Type and Year of Model Ts owned: Speedster (1919 w 1926)
Be careful in your purchase/ Check for sharp edges on the inner edge of the rimes and elongated bolt holes. Take pictures of what you have - lugs to incase you nee to buy the clamps. I''d even take one for a physical match
- Attachments
- rim.png (87 KiB) Viewed 961 times
