Set of Four Demountable Wheels, Rims and Tires
Topic author - Posts: 81
- Last Name: LaFalce
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster
- MTFCA Number: 32182
Converted our '26 Roadster to Model A wire wheels, these are the four wheels and tires removed from the car. $450 for all four, you arrange and pay for Fastenal shipping or pick up in Northern Alabama. Have all the spokes, those on rear wheels need to be pressed back into place, front wheels are intact. One clincher rim is from Hayes and another from Kelsey. The other two cannot be determined. Outer lug nut hole on one rim needs repair (see pic #2). Includes four hub flanges, but NO HUBS in this sale. Rear wheel nut/bolt/washer hardware is new from Lowes to keep the wheels together. Hardware on two front wheels is correct for a Model T. Tires are 21 x 4.0 - 5.25 and are serviceable, but recommend replacement. One tire has a very slow leak. 1 piece metal wheel rims measure 20 x 1 1/2.
- Attachments
- WoodWheel1.jpg (37.93 KiB) Viewed 1080 times
- WoodWheel2.jpg (26.15 KiB) Viewed 1080 times
- WoodWheel3.jpg (27.08 KiB) Viewed 1080 times
- WoodWheel5.jpg (25.78 KiB) Viewed 1080 times
- Wood Wheel 6.jpg (31.39 KiB) Viewed 1080 times
- First Name: Walt
- Last Name: Wise
- MTFCA Number: 12345
Re: Set of Four Demountable Wheels, Rims and Tires
I am no expert in anything, but are you sure those are 30 X 3.5 tires? The rims look like 21" too? On a 26, 21" tires would typically be on it? Again, I know very little...
- Last Name: Hanlon
- MTFCA Number: 50191
They are not clinchers....definitely a balloon tire rim.
