Set of Four Demountable Wheels, Rims and Tires
Horsehead
Last Name: LaFalce
* REQUIRED* Type and Year of Model Ts owned: 1926 Roadster
MTFCA Number: 32182
Post by Horsehead » Fri Sep 24, 2021 10:40 am
Converted our '26 Roadster to Model A wire wheels, these are the four wheels and tires removed from the car. $450 for all four, you arrange and pay for Fastenal shipping or pick up in Northern Alabama. Have all the spokes, those on rear wheels need to be pressed back into place, front wheels are intact. One clincher rim is from Hayes and another from Kelsey. The other two cannot be determined. Outer lug nut hole on one rim needs repair (see pic #2). Includes four hub flanges, but NO HUBS in this sale. Rear wheel nut/bolt/washer hardware is new from Lowes to keep the wheels together. Hardware on two front wheels is correct for a Model T. Tires are 21 x 4.0 - 5.25 and are serviceable, but recommend replacement. One tire has a very slow leak. 1 piece metal wheel rims measure 20 x 1 1/2.
Wood Wheel 6.jpg (31.39 KiB) Viewed 1104 times
Walt Wise
First Name: Walt
Last Name: Wise
MTFCA Number: 12345
Re: Set of Four Demountable Wheels, Rims and Tires
Post by Walt Wise » Fri Sep 24, 2021 11:24 am
I am no expert in anything, but are you sure those are 30 X 3.5 tires? The rims look like 21" too? On a 26, 21" tires would typically be on it? Again, I know very little...
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Fri Sep 24, 2021 12:12 pm
They are not clinchers....definitely a balloon tire rim.
