S4BF, Stromberg, Rayfield UF, U&J carb WANTED: filthy, unloved, or otherwise over-the-hill Brass Carbs - Picture Added
* REQUIRED* Type and Year of Model Ts owned: '13, '15, '19, '23
Post by Scott_Conger » Mon Sep 27, 2021 9:39 pm
Please pull it off the shelf and contact me. If you're not ever going to use it, turn it into some $$.
Thank you.
Last edited by Scott_Conger on Sat Nov 20, 2021 10:30 pm, edited 4 times in total.
NH Full Flow Float Valves
Re: S4BF carb WANTED: filthy, unloved, or otherwise over-the-hill Zenith S4BF
Post by Scott_Conger » Sat Oct 02, 2021 3:30 pm
Time for a bump
I know there's one out there
Bill Crosby
First Name: Bill
Last Name: Crosby
* REQUIRED* Type and Year of Model Ts owned: 1916 Touring, 1920 Coupe, 1926 RPU, 1927 RPU, 25 speedster project
Post by Bill Crosby » Sat Oct 02, 2021 3:38 pm
A picture might jog someones memory of that unknown carb on there shelf.
Post by Scott_Conger » Sat Oct 02, 2021 5:41 pm
Good point. Thank you Bill. Done.
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Re: S4BF carb WANTED: filthy, unloved, or otherwise over-the-hill Zenith S4BF - Picture Added
Post by Henry K. Lee » Sat Oct 02, 2021 6:14 pm
Scott have you been talking to the winter pixies again..., sounds like you know it is going to be a long hard winter!
Joe Bell
First Name: Joe
Last Name: Bell
MTFCI Number: 24066
Post by Joe Bell » Sat Oct 02, 2021 7:25 pm
I have the carb and intake I am hauling to Hershey c4i 29-31
Mikes 1912
First Name: Lester
Last Name: Husted
* REQUIRED* Type and Year of Model Ts owned: 20
Post by Mikes 1912 » Sat Oct 02, 2021 8:50 pm
yes I have one sitting on my desk, been there 6/7 years, maybe longer. I do not get in a rush. It has the sleeve that adj air intake and original bolts
that bolt it to the manifold. Mike 208 520 4892. Now that I look at it I have The intake manifold, also has zenith cast in it
Mikes 1912
First Name: Lester
Last Name: Husted
Post by Mikes 1912 » Sat Oct 02, 2021 8:52 pm
What is a Zenith worth, with the manifold?
FordFool
First Name: Don
Last Name: Kirtley
* REQUIRED* Type and Year of Model Ts owned: 13 and 16 touring, 18 and 20 coup, 20 tudor
MTFCA Number: 23703
MTFCI Number: 23153
Board Member Since: 2009
Post by FordFool » Sat Oct 02, 2021 9:09 pm
Lester. I bought one from Stan Howe about four years ago $750.00 plus shipping. Rebuilt carb with adjustable high speed jet and manifold. Hope this helps
Post by Scott_Conger » Sat Oct 02, 2021 9:45 pm
Lester/Mike/Joe I've sent you an email.
To all: parts of broken up/incomplete carbs considered, too.
thank you
First Name: Henry
Last Name: Lee
MTFCA Number: 479
Post by Henry K. Lee » Sun Oct 03, 2021 6:51 am
Scott,
I have misc. NOS screws in trays, odd throttle linkage stops/arms, old heavy brass fitting, etc. Let me know if you need this stuff.
Post by Scott_Conger » Sun Oct 03, 2021 9:35 am
Thank you Hank
email sent
Channel1tv
First Name: Bryan
Last Name: D
* REQUIRED* Type and Year of Model Ts owned: 1921 Center Door, 1923 Depot Hack. 1915 Rajo Speedster
MTFCA Number: 51668
Board Member Since: 2008
Post by Channel1tv » Wed Oct 06, 2021 7:59 am
I just bought a FA127X manifold here a few months ago for 160.00. If you have one I will buy it!
Shoot me a price.
If you find yourself the smartest person in your group of friends, it’s time to find some new friends!
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Wed Oct 06, 2021 2:01 pm
Sorry Scott,
All I have is a O4 Zenith and a L2P Rayfield. The plan was to show them some love but havn't found the time.
Post by Scott_Conger » Wed Oct 13, 2021 11:49 am
bump......
* REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
MTFCA Number: 52564
Post by Mark Gregush » Wed Oct 13, 2021 12:51 pm
OT The original style manifold did not have the throttle lever boss, and later reproduction did. That can affect the value. Personally, I like the ones with the boss, allows a wider range of carbs to be mounted.
1920 Dodge touring
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Wed Oct 13, 2021 1:27 pm
The stepped intake port on the sb4f manifold is designed to be that way to run properly. I have seen a few original manifolds that somebody tried to “fix” by grinding out the the step. Stan Howe talked frequently about the importance of having the correct manifold.
Post by Scott_Conger » Tue Oct 19, 2021 10:37 am
time for a bump...clean off the shelf and pocket some $$!
Post by Scott_Conger » Thu Oct 28, 2021 10:50 pm
again.....
67pontiac
First Name: William
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring 1913 Roadster 1919 TT 1920 Huckster 1922 Touring 1926 RPU
Board Member Since: 2010
Post by 67pontiac » Sat Oct 30, 2021 2:59 pm
Hi Scott, this is Bill Bennett in Visalia CA. I'm pretty sure I have one. Give me a call and we can talk particulars five five nine-nine six seven-0112
67pontiac
First Name: William
Post by 67pontiac » Mon Nov 01, 2021 10:50 am
Hi Scott, this is Bill Bennett in Visalia again. I definitely do have one. Are you still interested? If so, give me a call.
Re: S4BF, Stromberg, Rayfield UF, U&J carb WANTED: filthy, unloved, or otherwise over-the-hill Zenith S4BF - Picture Ad
Post by Scott_Conger » Sat Nov 20, 2021 10:29 pm
What do you have lurking on a shelf that's looking for a good home?
Re: S4BF, Stromberg, Rayfield UF, U&J carb WANTED: filthy, unloved, or otherwise over-the-hill Brass Carbs - Picture Ad
Post by Scott_Conger » Fri Nov 26, 2021 9:27 pm
Bill and I made a fair deal...how about you?
got10carz
Last Name: Meixner
MTFCA Number: 28023
MTFCI Number: 20471
Post by got10carz » Sat Nov 27, 2021 11:29 am
PM sent. Steve
Post by Scott_Conger » Mon Jan 03, 2022 11:25 am
Steve and I made a good deal...how about you?
also looking for Zenith intake manifolds
what have you got?
emails, please...thank you.
Ken Buhler
First Name: Ken
Last Name: Buhler
MTFCA Number: 49471
Board Member Since: 2012
Post by Ken Buhler » Mon Jan 03, 2022 3:49 pm
Hello Scott,
Are you still looking for more carbs? I have this one. If you want I will send it and you can pay after or credit for future.
Ken Buhler
Work honestly
Stay true to your word
Get the job done right
Post by Scott_Conger » Mon Jan 03, 2022 5:44 pm
Hi Ken, thank you. I've sent you an email
Post by Scott_Conger » Sun Jan 16, 2022 5:49 pm
ttt.......
