WTB: ‘25 Pickup Rear Fender Irons
Topic author - Posts: 95
- First Name: Kevin
- Last Name: Mocyk
- * REQUIRED* Type and Year of Model Ts owned: 1920 Touring
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
- MTFCA Number: 27211
Re: WTB: ‘25 Pickup Rear Fender Irons
when I was looking for them, I ended up buying the repros from Lang's
- First Name: Kevin
- Last Name: Mocyk
Unfortunately, Lang’s no longer has them available. When I spoke with Steve Lang back in August he said the person making them no longer wanted to make them so they were dropped from the current catalog.
- Last Name: Meixner
- MTFCA Number: 28023
- MTFCI Number: 20471
Get Langs #3858B and extend them about 2 inches. I've used these for 2 people.
- MTFCA Number: 121
- MTFCI Number: 16310
Gator was making them. He used an original of mine for the pattern.
- First Name: Mike
- Last Name: Metzentine
- * REQUIRED* Type and Year of Model Ts owned: 23 touring
U can make a set from the ‘touring’ irons! Just not as ‘thick’ from the flange out.
- First Name: Kevin
- Last Name: Mocyk
Thank you all for the suggestions, I actually have a pair of touring irons and if push comes to shove I’ll modify them to use.
I also want to thank member Bill Alexander for supplying the correct measurements to reproduce the originals.
I would like to find a pair of originals if possible-but based on the replies it seems that others have been down this road without much success!
- Last Name: Iaccino
- * REQUIRED* Type and Year of Model Ts owned: 1911 Roadster, Open Runnabout
- MTFCA Number: 17802
What is the length of the iron. I have a pair of these, but don't know if the ones I have are the correct length. John
- First Name: Kevin
- Last Name: Mocyk
Here are the measurements for the correct 25 Pickup rear fender irons. Total overall length is 9 1/4”. Again, special thanks to member Bill Alexander who supplied these measurements and gave his approval to my drawing.
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- MTFCA Number: 31662
- MTFCI Number: 23677
- Board Member Since: 2014
Is anyone making these now?
- First Name: Kevin
- Last Name: Mocyk
To my knowledge nobody is making them.
- MTFCA Number: 121
I've been keeping track of 1925 Pickups for years, and I'm up to about 135 now. Not bad for a pickup that I used to think was rare! I had reproduction irons on mine for awhile, until I found an original set.
- Last Name: Bobzin
Whoever was making them for Lang's must not be making them anymore.
Sorry it took so long to reply, but I had a hard time locating them after Hershey. The irons I have are 7 1/2 inches long including the threaded portion.
- First Name: Kevin
- Last Name: Mocyk
Sounds like you have the touring fender irons, I have a pair of those to modify if necessary they look the same as 3858B in Lang’s catalog.
- MTFCA Number: 121
I was at Kim Dobbins yesterday, and he has an original, but it has been cut in half, and only the tapered part is left.
