FOR SALE - STRONG SITE FEED OIL PUMP FOR FORDS NEW OLD STOCK IN THE ORIGINAL BOX
Jay In Northern Ca.
First Name: Jay
Last Name: Buscio
MTFCA Number: 49997
Post by Jay In Northern Ca. » Mon Oct 11, 2021 9:32 pm
Comes in the original box with the original installation instruction sheet. You will have to supply the oil lines of the sizes specified in the instruction sheet along with the washer that gets installed on the valve stem. A hollow front engine pan bolt (from a outside outline setup)Instead of the cam bearing hollow set screw as pictured on the instruction comes with this setup. I originally purchased this for my Model T accessory collection in 2003 and it has been on a display case shelf ever since. Time for it to find a new home! Asking $175 plus postage.
Please use this email address below and NOT the personal messaging system to contact me.
