WTB Low Speed Drum Australia
Topic author - Posts: 89
- First Name: Shawn
- Last Name: Barnard
- * REQUIRED* Type and Year of Model Ts owned: 1926 coupe
Is there anyone in Australia (Melbourne) that has a low speed drum for sale?
Thanks,
Thanks,
Re: WTB Low Speed Drum Australia
Shawn, I can help, but there's no way I am moving to Melbourne! You are as near as the post office for deliveries.
- First Name: Shawn
Bahahahaha. What's wrong with Melbourne? Its only the longest locked down place in the world.
Can you send me a message with a price to 3109?
Many thanks.
Many thanks.
Will do Shawn. Friday if I can't do it sooner.
Have a really nice one put aside. No grooves, no rust, nice gear and negligible wear on the gar shaft. Phone me on 0403 zero zero 3 9 zero zero.
- First Name: Jack
- Last Name: Tarlinton
- * REQUIRED* Type and Year of Model Ts owned: 1927 Cut off
I'm going to jump in here - Allan, if you have another low speed drum, I'm after one too!
Jack, I'll go back to digging in the pile. I knew of the one i picked out for Shawn. There are others, but I will have to check on their condition.
- First Name: Jack
Thank you Allan,
I'm also after a 26-27 driving plate. I have one in good condition but it is the earlier type and can't be used with the wider brake drum.
Best regards
Jack
Best regards
Jack
- MTFCA Number: 14383
It can be used. Cut down the OD & elongate the 6 mounting holes to match the drum hole pattern.Jack Tarlinton wrote: ↑Thu Oct 14, 2021 9:07 amThank you Allan,
Best regards
Jack
- First Name: Jack
True, but I'd rather save it for someone who can use it as it is, and hopefully I'll track down the correct part.
