FS MISCELLANEOUS NOS PARTS
Topic author - Posts: 3349
- Last Name: Chaffin
- MTFCA Number: 31705
Item description and price as indicated below. Shipping will be an additional $9.50 in most cases. PM me or call Mark Chaffin (951) 805-0928
#1 Clutch shaft NOS $20.00. SOLD OUT
#2 Front spring shackle set NOS Ford script $75.00. SOLD OUT
#3 Rear spring shackle set NOS Ford script $75.00. SOLD OUT
#4 Late style fan arms NOS (Lot of 3) $25.00.
#5 Early drive shaft spool sleeve NOS $25.00. Three additional available.
#6 Oil pan drain plugs NOS (Lot of 6) $20.00. SOLD OUT
Last edited by Mark Chaffin on Fri Oct 22, 2021 11:49 am, edited 9 times in total.
- First Name: Bill
- Last Name: Anziani
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coupe
Re: FS MISCELLANEOUS NOS PARTS
Mark, ill take the front and rear shackles
- MTFCA Number: 14383
Ill take 2 clutch shafts & both sets of drain plugs. Thanks - john
You got it John! Thank You.
One set of front and rear shackles sold. One set of each remaining.
- First Name: Shannon
- Last Name: Helm
Mark, I sent you a text about the remaining shackles.
Last set of fron and rear shackles sold to Shannon.
Prices reduced as indicated above for remaining items.
Remaining two clutch shafts have been sold. Thanks Adam!
