T-wrench for 1926 wire spoke wheel lugs - Found
Topic author - Posts: 12
- First Name: William
- Last Name: Gates
T-wrench for wire spoke wheels
PN: T2891 Marked 5-Z-161
- Last Name: Gates
Re: Need help finding a T-wrench for 1926 wire spoke wheel lugs
Can anyone help?
- First Name: Walt
- Last Name: Wise
- MTFCA Number: 12345
Mr. Gates,
see this link below on Ebay - not exactly what you are asking for, but maybe???
https://www.ebay.com/itm/353732730853?h ... ondition=4
Bidding ends today at 6:35pm EST and it currently has one bid of $20. If interested, don't bid until the last seconds of the auction if you want the best chance at it - my opinion... Not connected to the listing whatsoever...
- Last Name: Hanlon
- MTFCA Number: 50191
I did look to no avail....sorry.
- Last Name: Gember
- * REQUIRED* Type and Year of Model Ts owned: 1922 Touring 1926 Runabout 1926 Coupe
- MTFCA Number: 32303
- MTFCI Number: 16589
I have one. I sent you an email or email me: markpaulagember AT aol DOT com
These are like hens teeth, this is the only one I have ever found.
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
- MTFCA Number: 27211
William, You are looking for the wrong wrench. The 5-z-161 is a body bracket t handle wrench. You are looking for a part number 2891, factory number 2839 wire wheel wrench. I f I remember correctly it will have 2839 on the wrench. If you look in the '26 parts listing you will find it listed with the wire wheels, not the tools. There is no photo in the catalog of this wrench.
- First Name: Brian
- Last Name: Dowell
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring 26 Runnabout 19 Canadian Touring
- MTFCA Number: 52162
- MTFCI Number: 205
This is the correct one. Been looking for years. Found at Luray.
Life is Good, be nice.
- Last Name: Morsher
These were originally nickel plated. At least the couple examples I’ve had were. Kind of fuzzy, but I remember it being a dual use wrench.
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
In Bruce's book, towards the end of the tool listings, page 599, the 5Z161 has a note to use with wire wheel lugs.sweet23 wrote: ↑Wed Oct 27, 2021 8:07 amWilliam, You are looking for the wrong wrench. The 5-z-161 is a body bracket t handle wrench. You are looking for a part number 2891, factory number 2839 wire wheel wrench. I f I remember correctly it will have 2839 on the wrench. If you look in the '26 parts listing you will find it listed with the wire wheels, not the tools. There is no photo in the catalog of this wrench.
I have a T wrench marked; Ford T-2839, black coating, except where I cleaned if off to read the number.
1920 Dodge touring
1920 Dodge touring
- Last Name: Gates
Re: T-wrench for 1926 wire spoke wheel lugs - Found
I am all set on this now. Thanks for all the help!
- Last Name: Bobzin
Mark, Ford may have at one time told owners to use the 5-z-161 wrench. The '26 parts catalog clearly lists the T-2839 as the wire wheel lug nut wrench. I have one as well, with no sign of any plating.
- Last Name: Bobzin
Difficult to read part number because it is stamped around the wrench.
Great on finding one! Darryl, that is the same wrench I have sitting on my desk.
1920 Dodge touring
1920 Dodge touring
