In-the-original-box accessory FOR SALE
Dropacent
Last Name: Morsher
Post by Dropacent » Thu Oct 21, 2021 3:33 pm
I’ve always found it difficult to actually use a surviving original accessory that is in the original box. Case in point…….this is an original set of accessory hood hold downs, made by Stewart ( speedometer and various other accessory manufacturer). One of the arms was broken as they came to me, but a little epoxy and it did the trick. They are potmetal castings, so I’d suggest not using them, other than display, I did cast up a set for me out of aluminum, and you can do the same if you really want to use them. So, what you get is the original box and the original set of hold downs. $60 , ppd to your door. Tmorsher@icloud.com to reach me. Thanks!
