Model AA (1928 only) wire wheel front hubs (left and right) w/ lug nuts and brake drum $200.00)
Model AA (1928 only wire wheel front hub only (1) $60.00
Model AA wire wheel front brake drums (2) $25.00 each
Model AA wire wheel studs & lug nuts RH thread (5) $35.00
Model AA spare tire brackets (2) front fender mount $85.00
Four (4) TT brake backing plates --- 2 @ $50.00 pr & 2 @ $40.00 pr.
Three pairs of TT rear axle housings --- $30.00 pr.
Low speed worm drive gears for TT #1043 & #1044 --- $40.00.
TT brake drums $35.00 each.
Two flat style 1928 Model AA wire wheel hub caps $120.00 each.
Two cone style Model AA hub caps $50.00 each.
One 1928 Model AA 20" wire wheel less retaining ring $100.00.
Two (2) rear radius rods for Model TT $50.00 each.
Barn Fresh Stromberg OF carburetor $375.00.
Stewart speedometer mount flange #1070 for Model 160 speedometer $100.00
Brake shoes for TT #1056 $100.00 pr.
Rear spring hanger $60.00.
Worm thrush bearing assy. #1050 & 1051 $75.00.
Contact: Jack Leonhardt 920-226-1005
T, TT and AA Parts for sale
Topic author - Posts: 64
- First Name: Jack
- Last Name: Leonhardt
- * REQUIRED* Type and Year of Model Ts owned: 1926 Model TT Dump Truck w/ Weaver Model G 3 ton capacity wrecker boom.
- MTFCA Number: 23188
- MTFCI Number: 19556
Re: T, TT and AA Parts for sale
