Model A conversion for T
Topic author - Posts: 1056
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Have an A crank cut to fit the T block, rods fitted for crank , Egge Pistons for A rods in a T .060 over, main caps, reground cam. Tore engine down for repair and block has to many issue to reuse so customer is going back to Standard T crank and assembly. Give me a jingle if of interest. Thanks Joe
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
Re: Model A conversion for T
Joe:
sent email ...Gene French 970-581-2808
- First Name: Joe
- Last Name: Bell
Sorry I should of put a price on all of it 500. plus the ride, the crank has been shortened.
- First Name: Kevin
- Last Name: Prus
- * REQUIRED* Type and Year of Model Ts owned: 1910 Touring, 1912 torpedo, 1914 touring, 1919speedster, 1921 touring, 1922 touring 1925TTsemi, 1926 pickup, 1926 roadster
- MTFCA Number: 8047
- MTFCI Number: 190
- Board Member Since: 2004
Was it a McKee conversion with his name on the bronze caps
- First Name: Kevin
- Last Name: Prus
- MTFCI Number: 190
If it was McKees i will take it
- First Name: Joseph
- Last Name: Andulics
- MTFCA Number: 9766
Joe can answer the question definitively, but I saw the engine apart at Joe's, I don't believe it to be a McKee engine (he had done all my babbitt work before he retired). The pistons were real clean on the underside giving the appearance that it was a somewhat recent build.
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
Man, that would make a sweet bottom end for my Chevrolet over head!
1920 Dodge touring
1920 Dodge touring
- First Name: Terry
- Last Name: Woods
- MTFCI Number: 20180
Joe, is it sold to Gene? If not, I'm interested.Joe Bell wrote: ↑Wed Oct 27, 2021 12:07 pmHave an A crank cut to fit the T block, rods fitted for crank , Egge Pistons for A rods in a T .060 over, main caps, reground cam. Tore engine down for repair and block has to many issue to reuse so customer is going back to Standard T crank and assembly. Give me a jingle if of interest. Thanks Joe
- Last Name: Goertzen
- * REQUIRED* Type and Year of Model Ts owned: 1923 Touring, 1927 Runabout
- MTFCA Number: 50634
If nobody has committed to buying, I will buy it.
You mentioned that interested buyers should call you, but I couldn't find a phone number in your profile.
- First Name: Gene
- Last Name: French
Joe:
i will purchase at price stated ... sent email inquiry yesterday ... gene french 970-581-2808
- First Name: Joe
- Last Name: Bell
Gene was second man on list and heading his way, Thanks Joe
