Wire wheel looking for
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Mon Nov 08, 2021 6:58 am
I'm looking for one or two wire wheels for a freinds T, He has one that has broken spokes & would like to have a spare. The hubs look to be British?
Thanks.
Craig.
waynes wheel.jpg (26.28 KiB) Viewed 2526 times
waynes wheel2.jpg (28.33 KiB) Viewed 2526 times
First Name: Keith
Last Name: Townsend
MTFCA Number: 14778
MTFCI Number: 16305
Re: Wire wheel looking for
Post by KWTownsend » Mon Nov 08, 2021 9:02 am
Craig,
These folks can probably come up with some replacement spokes for you.
https://www.buchananspokes.com/
Keith
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon Nov 08, 2021 11:39 am
Pretty sure this is a standard MG wheel (TC/TD?). Check the Moss Motors catalog...
elliott1936
Last Name: Elliott
MTFCA Number: 9495
MTFCI Number: 9495
Post by elliott1936 » Mon Nov 08, 2021 1:21 pm
I have spokes that are 10 and 8 inches long that I will sell for a dollar a spoke. These are new from Buchanan's. Tom 503-644-9374
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Mon Nov 08, 2021 10:32 pm
Thanks for all the quick responces. Kieth i talked to Buchanan today. Kevin Yes I think you confirmed they are, looked at Moss web will try to contact tomorrow. Tom sent email will try to get measurements tomorrow.
Thanks everyone I think we are on to a solution.
Craig.
Wayne Mims
First Name: Ervin
Last Name: Mims
* REQUIRED* Type and Year of Model Ts owned: 12 rdstr 13 tor 14 tor 15 pickup 22 drs coupe 21 center door
MTFCA Number: 29375
Post by Wayne Mims » Mon Nov 22, 2021 10:27 am
looking for wire wheel
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Mon Nov 22, 2021 10:33 am
You should start your own wanted ad, along with saying what wire wheel you need. Besides the Ford Model T welded wire wheels, there are many other brands and types made for and fitted to Ts over the years, that could include Model A with adaptors.
1920 Dodge touring
Ruxstel24
Last Name: Hanlon
MTFCA Number: 50191
Post by Ruxstel24 » Mon Nov 22, 2021 11:27 am
I have a bunch of T wire wheels that are pretty rough....I’ll let them go cheap.
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Tue Nov 23, 2021 5:47 pm
Hi Mark,
Wayne is the friend I'm looking for the wheels for. He noticed I had not been responding to the post. He needs to repair one & get a spare for this car. we bothe have ford wires. Thanks guys we'll keep looking.
Craig.
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Tue Nov 23, 2021 6:58 pm
If they are, as pointed out MG wire wheels, how many do you need :D; https://www.ebay.com/sch/i.html?_from=R ... l&_sacat=0
Thanks for the info on whom the person is. Neither posting connect to one to the other, and considering how often people piggyback off other ads, did not know. ;)
1920 Dodge touring
Craig Leach
First Name: craig
Last Name: leach
MTFCA Number: 26647
Post by Craig Leach » Tue Nov 23, 2021 11:19 pm
Thanks Mark,
The wheel size seems to be the hard part to find. I'm not sure M.G. ever used a 21" wheel so these may be a highbred wheel. Yes some times people piggy back posts I did that once with out intending to kind of embarrassing when you figure out you did. Seems to be a rare wheel. I found 4 in 14" at goodguys but I don't think the oil pan will clear with those =)
Craig.
Last Name: Gregush
MTFCA Number: 52564
Post by Mark Gregush » Wed Nov 24, 2021 1:42 am
Could they be older like for MG-TC, TD or maybe Singer? AACA has a British section, wonder if maybe a post there and some help might be forth coming; https://forums.aaca.org/forum/63-britis ... aguar-etc/
1920 Dodge touring
Post by TRDxB2 » Wed Nov 24, 2021 2:24 am
They could be but the size of the wheel was never definitely stated other than " I'm not sure M.G. ever used a 21" wheel so these may be a highbred wheel" rim width would help and also the number of splines also a picture of the hubs and hubcap/knockoff.TA,TB,TC where 19"x2.5", 48 Spoke,
