Miscellaneous Ruckstell parts. The P202 (differential assembly), P139 (Bronze Thrust Plate) and (P144) Sun Gear look to be in good condition. Price for the lot is $150 plus $15.50 shipping. Mark Chaffin (951) 805-0928
FS RUCKSTELL PARTS
Topic author - Posts: 3327
- Last Name: Chaffin
- MTFCA Number: 31705
- First Name: Brian
- Last Name: Harlamoff
- * REQUIRED* Type and Year of Model Ts owned: 1913 Runabout, 1922 speedster
Re: FS RUCKSTELL PARTS
How much wear is acceptable in the holes in the differential carrier? The holes where the pins for the small gears go. I have a few where they are really oval. Some less so. These look a little oval to me. I was planning g on buying a new carrier assembly to cure this problem. Not necessary? Thanks
Less is better. I usually drill and install bushings. Easy 10 minute job.
Sold to Bill.
