WTB 23-25 Tall Firewall, Need a nice one!!
Topic author - Posts: 64
- First Name: Bryan
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1921 Center Door, 1923 Depot Hack. 1915 Rajo Speedster
- MTFCA Number: 51668
- Board Member Since: 2008
Need a nice clean 23-25 High/Tall Metal Firewall.
Thanks!!
Bryan
Thanks!!
Bryan
If you find yourself the smartest person in your group of friends, it’s time to find some new friends!
- Last Name: Hanlon
- MTFCA Number: 50191
Re: WTB 23-25 Tall Firewall, Need a nice one!!
I have one, I will have to get to it and make sure it’s a high one.
- MTFCA Number: 16175
- MTFCI Number: 14758
The high one (wiring hole above the terminal block) is 24-25. The low one (no hole) is 23 only.
- MTFCA Number: 121
- MTFCI Number: 16310
You should be more specific! Even though any high firewall will work, 1925's are different.
- Last Name: Hanlon
This is one I have. Light surface rust and the hole above the wire block as Steve stated.
- MTFCA Number: 14972
- MTFCI Number: 15411
As Larry stated the '25 is different in a couple areas most notably the 2 rivet patent plate - I see 4 holding that one.
Trying to learn.... I found an old thread where you observed several different variations of the high firewall. http://www.mtfca.com/discus/messages/41 ... 1399845339Original Smith wrote: ↑Fri Dec 03, 2021 9:51 amYou should be more specific! Even though any high firewall will work, 1925's are different.
From reading the responses its difficult to understand what changes would be on the same firewall. Would help to more specific to help us grade school T students understand better. I have a high '25 but with a pressed steel stay rod (need to look again). Note: in some discussions ambiguities occur. For example in the attached link I'm not sure if referencing changes are to both, low or high '25 firewall based on the sequence of responses.
By Larry Smith on Friday, May 09, 2014 - 09:22 pm:
I've seen at least four different styles of high firewalls. The differences are trivial, but they are there.
By Jack Daron - Brownsburg IN on Friday, May 09, 2014 - 09:37 pm:
Larry,Did the 25 firewall still have the holes where the priming bell crank went?
By Larry Smith on Friday, May 09, 2014 - 10:08 pm:
They did. Also the '25 firewall has 3 holes for the felt. The 1924's had 5.
By David Chantrell - Adelaide, Australia on Sunday, May 11, 2014 - 05:55 pm:
Also the high firewalls had a riveted bracket to hold the bonnet stay rod. The later ones it was pressed out of the metal and stamped in one piece. Over here the riveted design is the 1923-24 models with the 1925 the one piece stamped design.
So the picture is of a '25 high firewall with the 3 holes for the felt
Lastly, how do these '25 firewall differences relate to models or relative production dates (I see now id plate rivets as another subtle change) or does it matter?
- First Name: Bryan
- Last Name: D
I will take it Dave!
give me a call 352-638-2253
I wasn't to purist to the year as this is for a hack. I was just looking for a clean firewall.
I really like the education I get on this forum! Did not know there was a difference in the firewalls?
Best Regards MTFCA!
Bryan
