NEEDED Model TT ton Spring Clamps and front Engine mount
Channel1tv
First Name: Bryan
Last Name: D
* REQUIRED* Type and Year of Model Ts owned: 1921 Center Door, 1923 Depot Hack. 1915 Rajo Speedster
MTFCA Number: 51668
Board Member Since: 2008
Post by Channel1tv » Thu Dec 02, 2021 5:31 pm
Hello All!
In need of a pair of Front Spring Clamps and a tt front engine mount for a TT Front Spring!!!
The mount needs to have the 4 inch long threaded bolts as this is a 10 leaf spring.
IT would be nice to know the difference in thread length from year to year.
I was thinking I could used a 27 model front mount??
Thanks to all!!
Bryan
If you find yourself the smartest person in your group of friends, it’s time to find some new friends!
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Re: Model TT ton Spring Clamps Needed!!
Post by Mark Chaffin » Thu Dec 02, 2021 6:23 pm
Not everyone is out. We have a few sets on the shelf (3847B). Give Dave a call at the garage (951) 735-4791.
Channel1tv
First Name: Bryan
Last Name: D
MTFCA Number: 51668
Post by Channel1tv » Fri Dec 03, 2021 2:02 pm
Called Dave, he said no new ones in stock, but he would check to see if he had any used ones.
Mark Chaffin
Last Name: Chaffin
MTFCA Number: 31705
Post by Mark Chaffin » Sat Dec 04, 2021 2:06 am
He was mistaken. We have five sets on the shelf.
Channel1tv
First Name: Bryan
Last Name: D
MTFCA Number: 51668
Re: NEEDED Model TT ton Spring Clamps and front Engine mount
Post by Channel1tv » Wed Dec 29, 2021 7:42 pm
Still in need!! It is all I need to finish my 12 year project
Dave Young
First Name: David
Last Name: Young
* REQUIRED* Type and Year of Model Ts owned: 26 Touring, 26 RPU, 24 Coupe, 26 Speedster, 28 Chandler, 29 Chandler, 29 A
Post by Dave Young » Wed Dec 29, 2021 8:53 pm
Can you show a picture of it? I may have a few.
Scott C.
Last Name: Clements
MTFCA Number: 49592
Post by Scott C. » Thu Dec 30, 2021 9:58 am
I think that I have a TT front engine mount. It is larger than the one on my Coupe. I sent you an email.
Channel1tv
First Name: Bryan
Last Name: D
MTFCA Number: 51668
Post by Channel1tv » Thu Dec 30, 2021 12:47 pm
Here are the pictures of my mount,
As yo see it is too short by 1/2 to 3/4
I need one with a 4 inch depth.
The passenger cars are 3 1/2 form inside to tip of bolt
dobro1956
First Name: Donnie
Last Name: Brown
MTFCA Number: 49575
Post by dobro1956 » Thu Dec 30, 2021 8:13 pm
A real TT front spring clamp is unique to the TTs and uses a bigger bolt size, and also a clamp plate with larger holes. The car version is not correct on a TT. Ill look tomorrow at my TT spring clamps and see if I have a good one left. I was not aware that there are longer versions. Are you sure you do not have too many springs in the spring assembly???
Scott C.
Last Name: Clements
MTFCA Number: 49592
Post by Scott C. » Thu Dec 30, 2021 11:32 pm
Donnie, The TT mount has longer studs and they are 5/8" diameter as apposed to 9/16" on T's. Here are a couple of pictures comparing a TT mount to a T mount.
Channel1tv
First Name: Bryan
Last Name: D
MTFCA Number: 51668
Post by Channel1tv » Fri Dec 31, 2021 8:59 am
Got One!
Thanks to Scott C I have my Mount.
Still nothing on the Clamps. Looks as If I will have to make my own.
dobro1956
First Name: Donnie
Last Name: Brown
MTFCA Number: 49575
Post by dobro1956 » Fri Dec 31, 2021 12:16 pm
Thanks Scott. I knew the bolt size and hole size was different, but I never measured them to compare to a car spring clamp. Glad you had one for him. Most of mine are getting pretty sad as to condition.
have fun and be safe. Happy New Year's ....
