SOLD--Straight thru Carb. SIMMONS???
Jack Putnam, in Ohio
First Name: Jack
Last Name: Putnam
MTFCA Number: 13833
MTFCI Number: 13353
Post by Jack Putnam, in Ohio » Thu Dec 02, 2021 6:43 pm
I have an unbranded straight through carburetor. It is not labeled NH, believed to be Simmons. Very good condition,working flapper valve, has a brass float, very little side movement on throttle shaft and a new choke spring has been installed.$225 and that includes shipping. Paypal preferred. Jputnam(at)wcoil.com 419-3zero6=39sixsix
Last edited by Jack Putnam, in Ohio on Sun Dec 19, 2021 9:41 pm, edited 3 times in total.
scrawford
First Name: Stanley
Last Name: Crawford
* REQUIRED* Type and Year of Model Ts owned: None
MTFCA Number: 51859
Re: FOR SALE--Straight thru Carb.
Post by scrawford » Thu Dec 02, 2021 7:13 pm
Will work for a 1925?
First Name: Jack
Last Name: Putnam
MTFCA Number: 13833
MTFCI Number: 13353
Post by Jack Putnam, in Ohio » Thu Dec 02, 2021 7:57 pm
This carb will work on all years model T including the 1925.
First Name: Jack
Last Name: Putnam
MTFCA Number: 13833
MTFCI Number: 13353
Re: FOR SALE--Straight thru Carb. SIMMONS???
Post by Jack Putnam, in Ohio » Fri Dec 17, 2021 5:39 pm
back to the top
Shannon_in_Texas
First Name: Shannon
Last Name: Helm
Post by Shannon_in_Texas » Fri Dec 17, 2021 8:35 pm
Jack, I sent you an email.
Mike Lebsack-Iowa
Last Name: Lebsack
* REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
Board Member Since: 2008
Post by Mike Lebsack-Iowa » Fri Dec 17, 2021 9:38 pm
In my opinion, these run quite well. Mike Walker restored one for me and it runs very well!!
AandTman
First Name: Donald
Last Name: Vagasky
* REQUIRED* Type and Year of Model Ts owned: 26 Roadster 26 Touring 25TT C Cab express 26 Ames Speedster
MTFCA Number: 10280
MTFCI Number: 11688
Post by AandTman » Sat Dec 18, 2021 9:22 am
I thought Simmons had a heating element at the mounting flange.
* REQUIRED* Type and Year of Model Ts owned: Speedster (1919 w 1926)
Post by TRDxB2 » Sat Dec 18, 2021 11:38 am
Did an Internet Search based on the heater question.
This discussion shows a Simmons Super Carburetor with a heater coil and mentions that many NH parts were interchangeable
http://www.mtfca.com/discus/messages/41 ... 1406346710
This discussion shows a Duplex Carburetor which looks more like the one on MTFCA http://www.mtfca.com/discus/messages/33 ... 1372915657
In comparing some pictures the carb's profile looks like a Duplex Improved however the throttle flapper is different. If you keep reading you'll see the relationship between Simmons, Duplex \Wizard , Western Auto
A bit of confusion in this link viewtopic.php?t=6643
simmoms duplex.png (526.63 KiB) Viewed 1471 times
Duplex Improved Simmons https://mtfca.com/phpBB3/viewtopic.php?f=2&t=7205
Comparisons shows stampings & data plate on a Duplex Improved Carb (not seen in other links)
http://www.mtfca.com/discus/messages/70 ... 1498280187
Explains that Wizards were made by Simmons for Western Auto
http://www.mtfca.com/discus/messages/25 ... 1336560768
http://www.mtfca.com/discus/messages/70 ... 1507821949
