Wico Magnetos(2) type 184 C
Topic author - Posts: 835
- First Name: Gene
- Last Name: French
- MTFCA Number: 15614
- Board Member Since: 2014
for sale : 2 Wico Magnetos ... 1 has good spark , the other has no spark ... both have good caps and rotors ... i do not know the application , but think probably from farm implement or industrial engine ... the bakelite housing is broken on the non-working mag ... they mount on angle plate base housing ... clockwise rotation ... basic dimensions are 7" long , 4" wide , 5" height price $250 for the pair plus $16.20 flat rate priority mail postage in lower 48 states ... actual postage outside this area or INTERNATIONAL ... Gene French 970-581-2808
- First Name: Gene
- Last Name: French
Re: Wico Magnetos(2) type 184 C
these mags are an easy fit to many of the mag/accessory drives of the era... was going to use on an early 1916 Dodge Brothers , but located the correct Delco ignition unit ... still available, if interested make an offer ...will be listing on ebay this morning ... always an optimist ...Gene French 970-581-2808
