I have a set of AC Brakes for a TT ton truck. These are unmarked and I believe they were also sold under other names. I have seen them unmarked, marked AC or Stronghold, as well as others. This is the good AC design that gives brakes forward as well as reverse. It is a complete set including all the linkages and misc parts, but the springs, some of the small bolts, cable, bushings, and shoes, will need to be replaced. The setup will need restored, but all the little things that are usually missing are there. The main pivot stud has very little wear. There is one brass pivot stud bushing missing, I have included a bushing that fits the stud, but the OD is bigger than needed. I just included it as material to make the missing one out of. I show a picture of an old ad, of how the actuating system is installed. There is also a picture I found on the web, of the brackets installed on the rear axle housings. The axle housings are not included.
I have installed several sets of AC brakes. If a person has any questions about how to install, Ill be glad to help.
I will take 275.00 plus shipping for them. I will have to calculate the shipping as I have no way to "guess" how much it will be.
I accept pay pal "friends and family", check, or money order.
Please contact me at the info shown in the last photo. If you use the forum message system, I may miss your message.
Sold pending payment, AC Brakes for TT ton truck
Topic author - Posts: 1285
- First Name: Donnie
- Last Name: Brown
- MTFCA Number: 49575
- Last Name: Brown
- Last Name: Brown
- Last Name: Brown
Re: Sold pending payment, AC Brakes for TT ton truck
Sold pending payment. took only 19 minutes Thanks Richard and MTFCA
