For Sale: 1923 Engine
Topic author - Posts: 426
- First Name: Philip
- Last Name: Lawrence
- MTFCA Number: 5591
- MTFCI Number: 25062
- Board Member Since: 2014
This engine was found as a short block with transmission attached. It was in a farm yard and was well rusted in addition to having a damaged block above the water inlet. The timing cover was also broken.
I found a crankcase, transmission cover, cylinder head, timing gear cover in addition to a good 1923 bare block. I also have a fan assembly and a valve cover for it. Missing are a starter, generator, a set of bands and some nuts and bolts. $250.00 please respond by email only.
Last edited by Philip Lawrence on Sat Mar 19, 2022 1:14 pm, edited 4 times in total.
Re: For Sale: 1923 Engine
Here is the 1923 replacement block. Someone went crazy with red paint which I started to strip off.
All the parts to build a good 1923 engine are there. I've now found a starter and generator that I'm including $250.00
Last edited by Philip Lawrence on Sat Mar 19, 2022 1:12 pm, edited 3 times in total.
Still available
Last edited by Philip Lawrence on Tue Mar 08, 2022 11:08 am, edited 2 times in total.
Still available, I can deliver it to the Tulare Swap Meet in April if paid for in advance.
Last edited by Philip Lawrence on Tue Mar 08, 2022 11:08 am, edited 1 time in total.
To the top for another look.
still available.
