Wanted Kwik-Poly even partial cans
dobro1956
First Name: Donnie
Last Name: Brown
MTFCA Number: 49575
Post by dobro1956 » Fri Jan 14, 2022 7:47 pm
Does anyone have any kwik-poly. ? I need about 1/4 or a little less, of the original amount in the kit. As long as both parts are still liquid, it will still work for what I need it for.
dobro (at) artelco.com
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Re: Wanted Kwik-Poly even partial cans
Post by TWrenn » Fri Jan 14, 2022 7:50 pm
I wish they would still make the stuff!
Dale_mcm
First Name: Dale
Last Name: McMurry
* REQUIRED* Type and Year of Model Ts owned: 1910 Roadster
MTFCA Number: 2213
MTFCI Number: 5309
Post by Dale_mcm » Fri Jan 14, 2022 10:05 pm
Smiths Penetrating Epoxy will do the same thing.
* REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
MTFCA Number: 52564
Post by Mark Gregush » Fri Jan 14, 2022 10:14 pm
1920 Dodge touring
Larry
Last Name: Gresh
MTFCI Number: 15762
Post by Larry » Fri Jan 14, 2022 10:20 pm
I have a couple extra cans if you haven’t found any.
The cans are probably about 3/4 full and have been stored in a paint cabinet. They are sill liquid and should be fine. If you need them, message me your address and I can send them out in the morning.
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Post by TWrenn » Sat Jan 15, 2022 10:24 am
Thanks Mark! Lots of good epoxy's there... I'd choose either the Smiths or the "Total Boat" Penetrating Epoxy. They both seem
similar. For me, the important part is having it thin, then expanding. Kwik Poly was great for that, once when I temporarily used it to tighten spokes until replacement, I was shocked to see how it even flowed down from the tenens in the felloe down INSIDE the spoke and then came out of an almost indistinguishable fine crack in the spoke to seal it too! Figured that may have saved the spoke from completely busting before I could send it to Stutzmans.
dobro1956
First Name: Donnie
Last Name: Brown
MTFCA Number: 49575
Post by dobro1956 » Sat Jan 15, 2022 2:19 pm
Larry, I sent you an e-mail.
dobro1956
First Name: Donnie
Last Name: Brown
MTFCA Number: 49575
Post by dobro1956 » Sat Jan 15, 2022 8:05 pm
Mark, thanks for the link. There are some of those products I will need to try.
Larry had enough for my project. Thanks Larry, I owe you one.
