WTB #1800 swivel joint for 1911 ford
brian korth
First Name: brian
Last Name: korth
* REQUIRED* Type and Year of Model Ts owned: 1911 comercial roadster
MTFCA Number: 0
MTFCI Number: 8370
Post by brian korth » Thu Jan 20, 2022 9:53 am
still looking for # 1800 swivel speedometer joint for mid year 1911 ford. also need correct speedometer cable for same. to complete tool kit need correct spark plug wrench and hub cap wrench (may west style).
Last Name: Wrenn
MTFCA Number: 30701
MTFCI Number: 24033
Re: WTB #1800 swivel joint for 1911 ford
Post by TWrenn » Thu Jan 20, 2022 5:14 pm
Check with Russ Furstnow?
brian korth
First Name: brian
Last Name: korth
MTFCA Number: 0
MTFCI Number: 8370
Post by brian korth » Thu Jan 20, 2022 8:08 pm
have already talked with Russ, no luck
brian korth
First Name: brian
Last Name: korth
MTFCA Number: 0
MTFCI Number: 8370
Re: WTB speedometer swivel joint
Post by brian korth » Thu May 19, 2022 9:50 am
still looking for # 1800 swivel joint to fit 1911 speedometer set up. this has the threaded shaft to hold pinion gear not cotter pin
DontKnowMuch
Last Name: Sanford
* REQUIRED* Type and Year of Model Ts owned: 14 Touring, 26 Roadster, 27 Roadster
Post by DontKnowMuch » Fri May 20, 2022 10:54 am
I have part of the swivel joint you are looking for. Let me know if you are interested. I can send pictures. For some reason I’m having trouble adding pictures to this post.
Dennis
214-529-0478
DontKnowMuch
Last Name: Sanford
Post by DontKnowMuch » Fri May 20, 2022 11:04 am
This is the part I have. Gears move freely.
Dennis
brian korth
First Name: brian
Last Name: korth
MTFCA Number: 0
MTFCI Number: 8370
Post by brian korth » Sat May 21, 2022 5:59 pm
these pictures show the part i am looking for. any one have a complete one? there were three other styles used in 1911, would consider any of these.
brian korth
First Name: brian
Last Name: korth
MTFCA Number: 0
MTFCI Number: 8370
Post by brian korth » Sat May 21, 2022 6:03 pm
brian at (586-465-2306)
brian korth
First Name: brian
Last Name: korth
MTFCA Number: 0
MTFCI Number: 8370
Post by brian korth » Wed May 25, 2022 9:04 am
not having much luck in finding this part
brian korth
First Name: brian
Last Name: korth
MTFCA Number: 0
MTFCI Number: 8370
Post by brian korth » Tue May 31, 2022 9:30 am
to the top
