WTB #1800 swivel joint for 1911 ford
Topic author - Posts: 20
- First Name: brian
- Last Name: korth
- * REQUIRED* Type and Year of Model Ts owned: 1911 comercial roadster
- MTFCA Number: 0
- MTFCI Number: 8370
still looking for # 1800 swivel speedometer joint for mid year 1911 ford. also need correct speedometer cable for same. to complete tool kit need correct spark plug wrench and hub cap wrench (may west style).
- Last Name: Wrenn
- MTFCA Number: 30701
- MTFCI Number: 24033
Re: WTB #1800 swivel joint for 1911 ford
Check with Russ Furstnow?
- First Name: brian
- Last Name: korth
- MTFCA Number: 0
have already talked with Russ, no luck
- First Name: brian
- Last Name: korth
- MTFCA Number: 0
Re: WTB speedometer swivel joint
still looking for # 1800 swivel joint to fit 1911 speedometer set up. this has the threaded shaft to hold pinion gear not cotter pin
- Last Name: Sanford
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring, 26 Roadster, 27 Roadster
I have part of the swivel joint you are looking for. Let me know if you are interested. I can send pictures. For some reason I’m having trouble adding pictures to this post.
Dennis
214-529-0478
Dennis
214-529-0478
This is the part I have. Gears move freely.
Dennis-
- First Name: brian
- Last Name: korth
- MTFCA Number: 0
these pictures show the part i am looking for. any one have a complete one? there were three other styles used in 1911, would consider any of these.
- First Name: brian
- Last Name: korth
- MTFCA Number: 0
brian at (586-465-2306)
- First Name: brian
- Last Name: korth
- MTFCA Number: 0
not having much luck in finding this part
- First Name: brian
- Last Name: korth
- MTFCA Number: 0
to the top
