FOUND : Figure 8 front shackle
* REQUIRED* Type and Year of Model Ts owned: '23 cutoff, '25 touring, '27 touring
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Fri Jan 21, 2022 11:29 am
Thanks to Tim and Rich. They are sending me the shackles needed! That’s all for the comments!
Dan.
Figure 8 front shackle wanted, (1913-1917) with threaded boss for oiler.
Only one complete shackle needed, prefer one in good used condition, like this photo.
Thanks, Dan Treace
email: tmodelmanATcomcastDOTnet (replace AT with @ and DOT with . )
MTFCA Number: 121
MTFCI Number: 16310
Re: WTB: Figure 8 front shackle
Post by Original Smith » Fri Jan 21, 2022 11:37 am
I don't think half of that shackle is original.
* REQUIRED* Type and Year of Model Ts owned: Speedster (1919 w 1926)
Post by TRDxB2 » Fri Jan 21, 2022 11:44 am
Because of the oil hole positions? But which is the original, top-right?
Caswell
First Name: Dean
Last Name: Brevit
Post by Caswell » Fri Jan 21, 2022 11:49 am
You can't see low left but it will be threaded also, shackles require two oilers per set.
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Fri Jan 21, 2022 3:50 pm
LOL, great, now Dan needs two of them! :)
Harry Lillo
First Name: Harry
Last Name: Lillo
* REQUIRED* Type and Year of Model Ts owned: Speedsters, racers, depot hack, coupe
MTFCA Number: 13996
Post by Harry Lillo » Fri Jan 21, 2022 4:09 pm
Larry,
Could you tell us which half is correct for that year?
Harry Lillo
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Fri Jan 21, 2022 4:30 pm
To me this shackle is correct, at least for my use. Both pieces have oiler bosses.
Just need another like it to hang my front axle!
Post by TRDxB2 » Fri Jan 21, 2022 9:06 pm
This is the only one I have. All threads look good. Shaft is very worn and the end going through the shaft hole is a bit loose. There are no markings or numbers.
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Sat Jan 22, 2022 9:53 am
Thanks for the try Frank, you are right, a bit too worn out for use.
Appreciate the looking for that worn pair, but really need a set or one half of a front set in good to use shape!
Post by TRDxB2 » Sat Jan 22, 2022 10:59 am
I've read in the old Forums that some have tried to restore shackles, is that done, or only for those that are rare like Mae West's?
Last Name: Strange
MTFCA Number: 30944
MTFCI Number: 23667
Post by CudaMan » Sat Jan 22, 2022 11:18 am
Steve Jelf has welded up worn Mae West shackles and turned them back down to standard size on a lathe:
https://mtfca.com/phpBB3/viewtopic.php?t=2927
Dropacent
Last Name: Morsher
Post by Dropacent » Sat Jan 22, 2022 12:54 pm
Mark, ……..and then it broke on the way to greenfield village. He was lucky. VERY BAD idea to amateur repair any driveline part like that. It’s a pet peeve of mine, but as always, JMHO ! As Dan shows, good ones are out there , just ask. Also great reproduction parts from Chaffin’s
schwabd1
First Name: David
Last Name: Schwab
Re: FOUND : Figure 8 front shackle
Post by schwabd1 » Sat Jan 22, 2022 1:36 pm
I had some Mae West ones welded up….. a friend took them into the Jeep plant in Toledo, welded them up, turned them down and had them hardened to specs. It sure helps if you have the equipment available.
Dropacent
Last Name: Morsher
Post by Dropacent » Sat Jan 22, 2022 2:07 pm
That’s the rub, David. That’s for a professional to do. You can sleep at night, and so can the driver of the oncoming car.
