Wanted Spark and throttle rod spring collars
Topic author - Posts: 1098
- First Name: Mike
- Last Name: Bird
I'm in need of 1 pair of the spark and throttle rod spring collars. Not the cups
Thanks Mike Bird-
- MTFCA Number: 52564
Re: Wanted Spark and throttle rod spring collars
Used 1909 - 1916
https://www.modeltford.com/item/3528A.aspx
1920 Dodge touring
1920 Dodge touring
- First Name: Mike
- Last Name: Bird
Mark, Lang’s is out of stock.
- First Name: Alan
- Last Name: Stein
- * REQUIRED* Type and Year of Model Ts owned: 1911 Touring (August 1911)
- MTFCA Number: 7916
- MTFCI Number: 9631
According to Lang’s the guy that makes them doesn’t know when he will be able to make some more. So, not to piggyback/upstage Tbird’s want ad, after he finds a set I would like to be next in “the wanting to buy line” for another set so I can assemble and finish my column restoration. Are there two sets somewhere out there? astein.pls@gmail.com
- Last Name: Hatch
- MTFCA Number: 49974
What is wrong with original ones?
- MTFCA Number: 4838
- MTFCI Number: 115
Mike
I have a pair of those repros, send me your mailing address and they are yours.
Dan
email: tmodelmanATcomcastDOTnet (replace AT with @ and DOT with . )
Dan
- First Name: Mike
- Last Name: Bird
Thanks Dan!
I sent you my address
Mike
Mike
- First Name: Mike
- Last Name: Bird
Al, my next call was going to be Bob's Antique Auto. He has a lot of used parts in bins. He may have some...Bigal wrote: ↑Sat Jan 22, 2022 5:23 pmAccording to Lang’s the guy that makes them doesn’t know when he will be able to make some more. So, not to piggyback/upstage Tbird’s want ad, after he finds a set I would like to be next in “the wanting to buy line” for another set so I can assemble and finish my column restoration. Are there two sets somewhere out there? astein.pls@gmail.com
Mike
- First Name: Alan
- Last Name: Stein
Mike, Glad you found a set. Does anyone else have a pair? astein.pls@gmail.com
I posted the link more for information, than as a suggestion. I didn't know about them and figured others might not either.
1920 Dodge touring
1920 Dodge touring
