Wanted Spark and throttle rod spring collars
Tbird
Last Name: Bird
Post by Tbird » Sat Jan 22, 2022 10:36 am
I'm in need of 1 pair of the spark and throttle rod spring collars. Not the cups
Thanks Mike Bird
* REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
MTFCA Number: 52564
Re: Wanted Spark and throttle rod spring collars
Post by Mark Gregush » Sat Jan 22, 2022 1:29 pm
1920 Dodge touring
Tbird
Last Name: Bird
Post by Tbird » Sat Jan 22, 2022 2:01 pm
Mark, Lang’s is out of stock.
BigAl
First Name: Alan
Last Name: Stein
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring (August 1911)
MTFCA Number: 7916
MTFCI Number: 9631
Post by BigAl » Sat Jan 22, 2022 5:23 pm
According to Lang’s the guy that makes them doesn’t know when he will be able to make some more. So, not to piggyback/upstage Tbird’s want ad, after he finds a set I would like to be next in “the wanting to buy line” for another set so I can assemble and finish my column restoration. Are there two sets somewhere out there? astein.pls@gmail.com
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Sat Jan 22, 2022 5:53 pm
What is wrong with original ones?
* REQUIRED* Type and Year of Model Ts owned: '23 cutoff, '25 touring, '27 touring
MTFCA Number: 4838
MTFCI Number: 115
Post by DanTreace » Sat Jan 22, 2022 5:55 pm
Mike
I have a pair of those repros, send me your mailing address and they are yours.
Dan
email: tmodelmanATcomcastDOTnet (replace AT with @ and DOT with . )
Tbird
Last Name: Bird
Post by Tbird » Sat Jan 22, 2022 6:52 pm
Thanks Dan!
I sent you my address
Mike
Tbird
Last Name: Bird
Post by Tbird » Sat Jan 22, 2022 6:55 pm
Al, my next call was going to be Bob's Antique Auto. He has a lot of used parts in bins. He may have some...
Mike
BigAl
First Name: Alan
Last Name: Stein
MTFCA Number: 7916
MTFCI Number: 9631
Post by BigAl » Sat Jan 22, 2022 7:45 pm
Mike, Glad you found a set. Does anyone else have a pair? astein.pls@gmail.com
MTFCA Number: 52564
Post by Mark Gregush » Sun Jan 23, 2022 3:43 pm
I posted the link more for information, than as a suggestion. I didn't know about them and figured others might not either.
1920 Dodge touring
