non starter cars acc. starter
Topic author - Posts: 414
- First Name: Matt
- Last Name: Madison
- * REQUIRED* Type and Year of Model Ts owned: 1923
- MTFCA Number: 51525
Friend pulled this off a 1914 Touring owned by Harold Johnson of Salem Oregon made by Gray + Davis needs chain that ran from crank pulley gear up to motor -has two numbers on tags NO.2442366 and NO.1391467 - $400.00 ? call Matt 503-824-2681
- First Name: Jack
- Last Name: Putnam
- MTFCA Number: 13833
- MTFCI Number: 13353
Re: non starter cars acc. starter
What is in the box on top of the starter housing? Do you know that it works?
- First Name: Edmund
- Last Name: Niedzielski
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
Matt, may I suggest you show a close up picture of the electrical junction box that Jack is referring to . I have a model 301 that is very similar to yours. Both would have a junction box where the wiring for the lights and harness all meet up. Usually this box is supposed to be mounted on the firewall but perhaps by happy circumstance, maybe it is attached to your unit ?
- Last Name: Rogers
- Board Member Since: 2013
Man, that's quite the contraption!
- First Name: Matt
the box on top is a brake switch that they had wired into the system to make it operate my friend said it did engauge would be best to find someone with one to figure out operation.
