SOLD Frontenac vale cover, original unmolested FS
Topic author - Posts: 3384
- Last Name: Morsher
SOLD ORIGINAL UNMOLESTED aluminum valve cover for the Frontenac OHV head. You’ve heard of unobtanium? Here you go. Tmorsher@icloud.com no repairs, no extra holes Tim made the bad mistake of buying a reproduction years ago. Don’t make the same mistake Tim did. Tmorsher@icloud.com to reach me. Thanks!
- First Name: Joe
- Last Name: Bell
- MTFCI Number: 24066
Re: Frontenac vale cover, original unmolested FS
Tim, why don't you repop a couple so then there will be more unobtainables?
- First Name: Mike
- Last Name: Lebsack
- * REQUIRED* Type and Year of Model Ts owned: 11Torpedo, 11 Roadster, 13 Touring, 14 Roadster, 14 Touring
- Board Member Since: 2008
Just curious, what kinds of problems are there with the reproductions? I may have committed a “Tim mistake” too!!
Really shitty casting, and it was wayyyy undersized. I think likely an original was just used as a pattern and lots of shrink in aluminum. If it was easy , everyone would do it. In all fairness, that was a long time ago and perhaps they’ve been improved, I sure don’t know. I only get burned once. Mine has 100 years of pedigree and every scratch is a story. If you bought a repo one ( and I’m not sure if he made fronty covers ) from Dan McEachern , you will be pleased, otherwise don’t say you weren’t warned.
Joe, it would cost me $1000 to make the first one. I’m not the sharpest knife in the drawer, but don’t see an upside.
- First Name: DAN
- Last Name: MCEACHERN
I've never offered a Fronty cover because others were making them, and I'm a firm believer that this hobby does not need, nor can it support multiple sources for the same part. The issue with using an old valve cover for a pattern is that aluminum shrinks 3/16" per foot so an 18" long part comes out almost .3" shorter, enough to make an ill fitting reproduction. My Rajo and 8 valve Roof covers are cast using matchplate patterns and hardsand cores so that the castings are top quality and fit - almost better than originals.
What Dan said ! I bought a Rajo cover from him a long time ago. The only thing wrong was it was a far better quality casting than an original. And, it fit like a glove!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
All of Dan's stuff made my engines look and fitted GREAT!
Bump with new price, $500 ppd tmorsher@icloud.com
Re: SOLD Frontenac vale cover, original unmolested FS
Sold, thanks!
