FOR SALE: Spare tire carrier for 26-27 pick up T Truck
Topic author - Posts: 387
- First Name: Jack
- Last Name: Putnam
- MTFCA Number: 13833
- MTFCI Number: 13353
This is a new reproduction spare tire carrier for the 26-27 T pickup truck. Made using the original Ford blue prints. Available now. $600 plus the ride to you. PayPal between friends, check, or pictures of dead presidents if you pick up. 419-3 zero six-39 six six. Jputnam(at)wcoil.com.
- First Name: Jack
- Last Name: Putnam
Re: FOR SALE: Spare tire carrier for 26-27 pick up T Truck
This carrier can be used with wire or wood spoked wheels with the "Y" bracket.
- First Name: Jack
- Last Name: Putnam
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- MTFCA Number: 31662
- MTFCI Number: 23677
- Board Member Since: 2014
Will this fit a 25 pickup with 30 inch tires?
- First Name: Jack
- Last Name: Putnam
No. The distance from the running board to the top mount post is different.
- MTFCA Number: 121
- MTFCI Number: 16310
There is also a small metal plate that goes under the carrier.
- First Name: Jack
- Last Name: Putnam
The shim plate is there. Just hard to see in the pictures.
- First Name: Jack
- Last Name: Putnam
You can mount wire or split rims with this carrier. Split rims require the Y bracket
