FOR SALE: Spare tire carrier for 26-27 pick up T Truck
Posted: Tue Apr 12, 2022 6:08 pm
by Jack Putnam, in Ohio
This is a new reproduction spare tire carrier for the 26-27 T pickup truck. Made using the original Ford blue prints. Available now. $600 plus the ride to you. PayPal between friends, check, or pictures of dead presidents if you pick up. 419-3 zero six-39 six six. Jputnam(at)wcoil.com.
Re: FOR SALE: Spare tire carrier for 26-27 pick up T Truck
Posted: Sat Nov 26, 2022 11:31 am
This carrier can be used with wire or wood spoked wheels with the "Y" bracket.
Posted: Mon May 01, 2023 10:50 pm
Back on top.
Posted: Wed May 03, 2023 12:33 pm
by SurveyKing
Will this fit a 25 pickup with 30 inch tires?
Posted: Thu May 04, 2023 10:33 pm
No. The distance from the running board to the top mount post is different.
Posted: Fri May 05, 2023 12:52 pm
There is also a small metal plate that goes under the carrier.
Posted: Fri May 05, 2023 1:27 pm
The shim plate is there. Just hard to see in the pictures.
Posted: Fri May 05, 2023 1:33 pm
You can mount wire or split rims with this carrier. Split rims require the Y bracket
