Bauer steering wheel
Rodbolt
First Name: Al
Last Name: Haines
* REQUIRED* Type and Year of Model Ts owned: 1923 touring. 1924 Roadster
MTFCA Number: 51396
Post by Rodbolt » Wed Apr 27, 2022 1:44 pm
Fs Bauer steering wheel ,nice shape ,tight wood
$595.00 plus the ride
Grand63@hotmail.com
Rodbolt
First Name: Al
Last Name: Haines
MTFCA Number: 51396
Re: Bauer steering wheel price reduction
Post by Rodbolt » Sun May 01, 2022 2:54 pm
Reduced to $500.00 plus shipping
Rodbolt
First Name: Al
Last Name: Haines
MTFCA Number: 51396
Post by Rodbolt » Sun May 15, 2022 8:31 am
Any offers?
DontKnowMuch
Last Name: Sanford
* REQUIRED* Type and Year of Model Ts owned: 14 Touring, 26 Roadster, 27 Roadster
Post by DontKnowMuch » Sun May 15, 2022 9:45 am
What was attached to the three holes around the steering column hole? I assume the other hole was for a horn wire.
Thanks.
ThreePedalTapDancer
First Name: Ed
Last Name: Martin
Post by ThreePedalTapDancer » Sun May 15, 2022 10:48 am
It had an optional horn button.
Post by Allan » Mon May 16, 2022 6:39 am
That accessory horn button mount does not cover the three holes. On Us cars there was never a need for a special mounting for a horn button. Early 1915 cars with magneto horns had the horn button on top of the steering column. Then it moved to the side of the column after that.Perhaps there was something else fitted to this particular wheel.
My wheel, purchased at Chickasha in 2010 has no holes. It is mounted with the usual steering wheel nut. In my case, the Canadian horn button is attached to the nut in the usual way.
They are really nice wheels to use, and a source of many curious questions by onlookers.
Ratfink56
First Name: Duane
Last Name: Epper
* REQUIRED* Type and Year of Model Ts owned: 1910 Touring
MTFCA Number: 0
Post by Ratfink56 » Mon May 16, 2022 11:26 pm
There were 2 different Bauer Fatman steering wheels for the Model T . One had a single hole for the horn wire and you could use an aftermarket horn button. The other came with a horn button assembly and was held in place with 3 screws. The one you have for sale would use Bauer's horn button assembly.
Post by Allan » Mon May 16, 2022 11:51 pm
Thanks Duane. That switch would cover the three holes in the vendor's wheel. Good spot. Presumably both styles of buttons would require a free loop of wire under the wheel, just like the Canadian horn buttons require. I guess the aim was to put the horn button in a more convenient position
