Spiral wound rear axle roller bearings F/S
Topic author - Posts: 1498
- First Name: Layden
- Last Name: Butler
USED rear car axle spiral wound roller bearings part # 2508, these are for both inner and outer and left and right side, lightly used very good condition and measure .002" wear or less on the rollers, no loose cages, limited number available, most have no makers markings but some say Hyatt and a few Ford, all are the original style spiral wound rollers and probably date from the 1920s, they have been cleaned in solvent but you should clean again to get any residual out of the inside of the rollers, price is $75 each, domestic postage is a flat $15 per order regardless of number ordered.
- Last Name: Butler
Re: Spiral wound rear axle roller bearings F/S
Happy purchasers to date! Limited number still available and then they will be gone.
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
I have what I need of these, but many don't - Thank you for making these available, sure hope that those that need them take advantage.
- Last Name: Butler
Maybe last call for these before they are gone!
- Last Name: Tipton
- MTFCA Number: 31392
- MTFCI Number: 23748
Layden,
Just set you an email.
Dave Tipton
Dave Tipton
- Last Name: Butler
One more time around!
- Last Name: Butler
This may be the last time offered!
None have ever been returned!!
