Stevens Tapered Reamers??? UPDATE
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Mon May 02, 2022 6:33 pm
I have been getting a number of inquiries for my Stevens Tapered Upper Reamers. I am considering another run. Due to increased cost the price is going to be in neighborhood of $250.00 + shipping.
I will need at least 7 orders for this to happen.
Email me at address in pictures to reply.
If I get enough interest I will look into another run of reamers/taps.
Thanks Dan
I HAVE 2 REAMERS LEFT as of 5/23/22.
If you want one speak now.
Last Name: Tannehill
MTFCA Number: 49460
Re: Stevens Tapered Reamers???
Post by JTT3 » Mon May 02, 2022 10:53 pm
You know I’m in.
dobro1956
First Name: Donnie
Last Name: Brown
MTFCA Number: 49575
Post by dobro1956 » Tue May 03, 2022 9:44 am
Dan, I'll take one. Will also send you an e-mail.
MTFCA Number: 49460
Post by JTT3 » Tue May 03, 2022 1:29 pm
Come on gals & guys we need to get to at least 7. If you have an original reamer you’re on borrowed time plus you should see the one Dan has reproduced. It’s longer so that it can be sharpened, really a quality piece and yes I’m being selfish I’d like to have at least one more before they are not available.
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Tue May 03, 2022 5:38 pm
Up to 4 need 3 more to sign up .
Brian Cress
First Name: BRIAN
Last Name: CRESS
* REQUIRED* Type and Year of Model Ts owned: Speedsters, Roadster, Hack
MTFCA Number: 29555
MTFCI Number: 15565
Post by Brian Cress » Tue May 03, 2022 6:28 pm
Hi Dan,
Russ Potter has asked me to add his name to the list.
Just two more to go!
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Tue May 03, 2022 6:48 pm
Brian got your email and another one too. We are at 6. Thanks guys . Dan
Jim, Sr.
First Name: Jim, Sr.
Last Name: Rodell
* REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
MTFCA Number: 2406
MTFCI Number: 22213
Post by Jim, Sr. » Tue May 03, 2022 10:58 pm
Dan, Are they the straight taper, or the spiral cut that draws itself into the hole?
1922 Coupe , 1926 Touring
Brian D
First Name: Brian
Last Name: Dowell
* REQUIRED* Type and Year of Model Ts owned: 14 Touring 26 Runnabout 19 Canadian Touring
MTFCA Number: 52162
MTFCI Number: 205
Post by Brian D » Wed May 04, 2022 2:22 am
I'm in for one,
Brian Dowell
Life is Good, be nice.
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Wed May 04, 2022 8:09 am
Straight
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Wed May 04, 2022 8:54 am
Reamers will be ordered today!
I am checking on the reamer/taps.
Stay tuned for more updates. Thanks Dan
MTFCA Number: 49460
Post by JTT3 » Wed May 04, 2022 10:24 am
Dan thanks for doing this.
Hey Forum if you even think that you may need a reamer for your Stevens tool, you need to get in contact with Dan so he can add to the order before it’s too late. More than likely this will be a last chance opportunity. Best John
SteveD
First Name: steven
Last Name: davidson
* REQUIRED* Type and Year of Model Ts owned: 1924 touring
MTFCA Number: 51591
Post by SteveD » Wed May 04, 2022 12:06 pm
Dan, got your email, thanks for doing this.
dobro1956
First Name: Donnie
Last Name: Brown
MTFCA Number: 49575
Post by dobro1956 » Wed May 04, 2022 1:52 pm
I agree with JTT3. If you think you may ever need another set, I would get on this boat before it sails. Even with proper use the reamer's do not last forever. The original taper reamer's are made of unobtanium. Dan's taper reamer's have been the only likely way to make a Steven's Front Axle tool complete and usable. His reamer's are top notch items. Thanks Dan,for making them available one more time. Now I can have a complete back up set.
Mark Wing - NM
Last Name: Wing
* REQUIRED* Type and Year of Model Ts owned: 1910 Tourabout, 1911 touring, 1913 touring, 1924 coupe, 1925 touring
MTFCA Number: 29346
Post by Mark Wing - NM » Thu May 05, 2022 1:56 am
Hi Dan,
I just ran across this threat and would like to be added to the list if I'm not too late. I sent you an e-mail.
Thanks,
Mark Wing
Mark Wing - NM
Last Name: Wing
MTFCA Number: 29346
Post by Mark Wing - NM » Thu May 05, 2022 1:57 am
That should read "thread".
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Wed May 18, 2022 9:01 pm
Back to the top. Also see reamer/tap thread. You need to let me know if you want one too.
Tapered readers all most gone.
nigel_hugo
First Name: nigel
Last Name: hugo
* REQUIRED* Type and Year of Model Ts owned: 1911 T touring car
Post by nigel_hugo » Thu May 19, 2022 8:26 am
Hello Dan, if you have a complete kit available, the stevens tool, the tapered reamer, and the lower tapping tool. please can you let me know what you have. Many thanks. Nigel Hugo.
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Thu May 19, 2022 9:00 am
As of right now I think there is one tapered reamer left, reamers/taps, upper & lower inserts. Jack May have some frames. Thanks Dan
* REQUIRED* Type and Year of Model Ts owned: '13, '15, '19, '23
Post by Scott_Conger » Thu May 19, 2022 9:24 am
Hi Dan
I had emailed my desire for a tapered reamer and am "on the list" I believe...are you wanting payment or just another promise to buy one...I hope to not miss out. Thanks.
NH Full Flow Float Valves
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Thu May 19, 2022 10:04 am
Scott you are on list. Waiting for the reamers to be made. I will start notifications when I get them in hand. Thanks Dan
hah
Last Name: hardiman
* REQUIRED* Type and Year of Model Ts owned: 26 coupe
Post by hah » Thu May 19, 2022 10:54 pm
Hi Dan
You have 2 threads:
1 tapered
2 front axle
Are they the same? If not what's the tapered unit used for?
John
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Fri May 20, 2022 5:08 am
Not the same. Takes one of each to fix axle. Pictures worth 1000 words
https://www.youtube.com/watch?v=7DNGT7P79vg
Randall strickland
First Name: Randall
Last Name: Strickland
Post by Randall strickland » Sat May 21, 2022 7:23 am
Dan here's one I made a while back doing it with axle still in car
https://www.youtube.com/watch?v=v9YJvzcyNHw&t=10s
nigel_hugo
First Name: nigel
Last Name: hugo
Post by nigel_hugo » Sat May 21, 2022 9:18 am
Dan, I am in for the tapered reamer, the drill and tap for the bottom hole.
Thanks, Nigel Hugo.
Last Name: Hatch
MTFCA Number: 49974
Re: Stevens Tapered Reamers??? UPDATE
Post by Dan Hatch » Mon May 23, 2022 1:50 pm
See first post for updates.
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Wed May 25, 2022 8:24 pm
2 left . Get on list now or lose out.
Brian D
First Name: Brian
Last Name: Dowell
MTFCA Number: 52162
MTFCI Number: 205
Post by Brian D » Thu May 26, 2022 6:59 am
Dan
I was on the list I believe for the reamer! I would also like the reamer tap.
Please let me know!
Brian
586 864 5110
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Thu May 26, 2022 8:36 am
Email sent . Thanks Dan
Sarikatime
Last Name: Seress
MTFCA Number: 27707
Post by Sarikatime » Fri May 27, 2022 9:46 am
Dan, how much will it cost me for an upper tapered reamer and for the lower reamer/tap.
Frank
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Fri May 27, 2022 11:36 am
Prices are in first post of each thread.
Upper $250.00
Lower $200.00
+ shipping
If you want a set email me at address in pictures ASAP.
Thanks Dan
SteveD
First Name: steven
Last Name: davidson
MTFCA Number: 51591
Post by SteveD » Fri May 27, 2022 4:55 pm
Dan, will we be able to purchase tapered and threaded inserts from you when the reamers are ready?
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Fri May 27, 2022 7:47 pm
Yes I have them in stock
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Sun May 29, 2022 1:32 pm
Back to the top
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Tue May 31, 2022 2:39 pm
Have a couple left
Last Name: Hatch
MTFCA Number: 49974
Post by Dan Hatch » Tue Jun 07, 2022 8:53 am
Still have one set left!
Sarikatime
Last Name: Seress
MTFCA Number: 27707
Post by Sarikatime » Sun Jun 12, 2022 10:02 am
Dan, do you have any tapered reamers left? I would like one please. Also a couple set of inserts to go with that when the reamers are ready.
Frank
