WANTED: 26/27 Stop Light - Bracket Only
Posted: Tue May 03, 2022 1:43 pm
Looking for the 26/27 stop light bracket, circled. I have all the rest.
Thanks!
Email to: jerryvan65 AT yahoo DOT com
Re: WANTED: 26/27 Stop Light - Bracket Only
Posted: Tue May 03, 2022 2:54 pm
I think I have one. My be a repro not sure
Posted: Tue May 03, 2022 3:12 pm
Not sure if original - stamped DUOLAMP-B $6 plus shipping
Posted: Wed May 04, 2022 12:37 pm
Thanks Frank. Most appreciated, but I believe that's for a Model A.
Posted: Sun May 08, 2022 7:43 am
Still looking...
Thanks to Frank, who tried to help me out. Not so much thanks to the scammers who replied with their usual B.S.
Posted: Sun May 08, 2022 1:58 pm
by Dan Hatch
Jerry you coming to Luray? Think there is one in swap meet trailer.
Posted: Sun May 08, 2022 3:53 pm
No Dan, I can't make it this year. I think I know of a friend who's going though. Do you have an assigned vendor space he could go to?
Posted: Mon May 09, 2022 12:19 pm
Dan Hatch???
Posted: Mon May 09, 2022 1:06 pm
by Dan Hatch
False alarm. When and looked to be sure. Mine is just the plain tail light bracket. Not the Stop light bracket.
Posted: Mon May 09, 2022 3:54 pm
Thank you Dan. I appreciate your taking the time to check it out! :)
Posted: Mon May 09, 2022 4:13 pm
Jerry
Those 26-27 Stop +Tail license brackets are rare as hen's teeth.
So I fab'd one using the repop Synders 28-29 drum license bracket, cut the sides away, and drilled hole and cut straight sides to make that 'oblong' hole for the lamp socket and to clear the rear lamp bump. The sides of the 28-29 Model A bracket are narrow, but just enough 'meat' to drill holes for the nuts to secure the lamp's studs. Works, looks 'almost' authentic ;)
ORIGINAL
WHAT WAS USED
RESULT
Posted: Mon May 09, 2022 4:24 pm
Jerry
ORIGINAL
WHAT WAS USED
RESULT
Thanks for sharing this HOT tip.
This is a great option over the unobtanium original piece.
Posted: Mon May 09, 2022 7:21 pm
by Model T Matt
look in Dodge after market parts they have the lens so maybe the bracket is the same
Posted: Mon May 09, 2022 9:02 pm
Jerry
Dan,
Great suggestion! Thank you!
Matt,
Definitely worth looking into!
Posted: Tue May 10, 2022 12:34 pm
by Mopar_man
So this is a 26/27 tail light bracket. I see from the picture that the one you are looking for is a bit different than mine. I didn't know they made two kinds. This is not what you are looking for is it?
Posted: Tue May 10, 2022 12:46 pm
No. He's looking for the bracket for the accessory stop/running light. There is no lip to mount the can & the back is larger.
Posted: Tue May 10, 2022 12:49 pm
by Mopar_man
Got it. Thanks! Hope he finds one.
Posted: Thu May 12, 2022 8:16 pm
by Melba Nolan
call me at 314-575-7115 and I will text you a picture of one I have, if its right
Posted: Sat May 14, 2022 8:01 pm
I don't text. Can you send me a photo by PM or email from the forum?
Posted: Fri May 20, 2022 6:42 pm
by Larry
Hi Jerry,
If you have not found a stop light bracket yet, I have a couple complete original ones if you are interested.
Posted: Fri May 20, 2022 7:57 pm
by Larry
Posted: Sat May 21, 2022 11:17 am
Thanks Larry. That looks close, but not quite "it". I think I'm going to just modify one that I've got, as others have suggested.
Posted: Sat May 21, 2022 2:52 pm
by Larry
Sounds Good Jerry!
Posted: Sat Nov 12, 2022 10:03 pm
by Mr. T Ford
I have a bracket it interested
Posted: Sat Nov 12, 2022 11:29 pm
by ModelTWoods
Thanks!
The Ford accessory stoplight and license bracket is not the same as either one of the two Dodge styles that were made. Study the picture that Jerry posted and then, compare it against either one of the two Dodge brackets or a 28-29 A drum taillight bracket. Close, but no cigar. To the untrained eye, one can be fooled easily; be careful. The correct Ford bracket will have an oval shaped hole in the bracket where the back of the light socket/wiring plug extends through the bracket. The oval shaped hole will be wider at the top of the oval, than at the bottom, if I remember correctly. A lot of other "look alike" tail light brackets will have only a round hole for the socket to extend through. The good thing is that if authenticity is not your bag, either one of the two Dodges can be made to work easier than modifying a reproduction Model A Duolamp bracket. The stoplight itself bolts right to the Dodge or Ford bracket, but to bolt the Dodge bracket to a 26-27 T tail light stanchion, the holes in the bracket must be modified to match those in the stanchion. How do I know so much, I've done a few. I, even, tried to modify a Duolamp bracket like Dan Treace did; never again. Dan how did you find the metal that the reproduction Duolamp bracket was made from ? I ruined, broke and dulled, drill bits and used up so many grinding discs for my Dremel tool that I had to go to Lowe's to buy more. I swear, that was the toughest metal I've ever found on a pressed steel reproduction part. By the way, the Ford and Dodge stop lights were made by the C. M. Hall Mfg. Co. Huppmobile and a few other more expensive makes used there own version.
Posted: Sun Nov 13, 2022 8:50 am
Yes, I'm interested. Can you post a photo or send one to me via PM or email please?
Thanks!
Posted: Sun Nov 13, 2022 1:40 pm
by Craig Leach
Jerry,
Speedway Motors #91138102 they sell it as a 1932?
Craig.
Posted: Sun Nov 13, 2022 8:50 pm
by ModelTWoods
Jerry,
Craig.
Very close; even closer than a Model A Duolamp bracket, but certainly can be told from the real thing, even if you get the one painted black.
Posted: Wed Nov 16, 2022 12:26 pm
Thanks!
Mr. T? Haven't heard back from you. Do you still have the bracket?
Posted: Wed Nov 16, 2022 6:05 pm
by ModelTWoods
Thanks!
Jerry, If you are looking for "the real thing", be very cautious about buying, without a hands on inspection. Insist on photograph of actual part that you are paying for and will receive. Words of caution.
Posted: Wed Nov 16, 2022 6:17 pm
Thanks Terry!
