ORIGINAL Martin-parry cab door handle
Dropacent
Last Name: Morsher
Post by Dropacent » Fri May 06, 2022 6:39 pm
Here is an original Martin-Parry wood cab inside and outside door handle. These have a square steel shaft with the cast iron poured right on the shaft. Has the inside handle, and the small escutcheon for on the wood door. Beadblasted and powder coated. $80 ppd to your mailbox. Tmorsher@icloud.com to reach me, thanks!
