This is a reproduction of a period accessory that helps reinforce the front of your frame. Also known as “Henry’s Necktie”. I had several sets of these cast from an original set. Each hook is placed on a front fender brackets and the tie rod connects them to help prevent the frame rails from spreading apart due to the constant pounding that the crossmember takes from bumpy roads. A must have if you put a lot of miles on your T.
$65 plus shipping gets you a set of hooks and tie rod to your door. Please send me an email (not a private message). My email address can be found by clicking on my profile.
**PLEASE NOTE**
Due to the changes Ford made to the fender brackets over the years, these will only fit front fender brackets from 1913-1925.
New Part For Sale: Front End Accessory Frame Brace
Topic author - Posts: 662
- First Name: Ed
- Last Name: Fuller
- MTFCA Number: 29582
- MTFCI Number: 22818
- Board Member Since: 2012
Re: New Part For Sale: Front End Accessory Frame Brace
Check out this copy of the original ad!
- First Name: Henry
- Last Name: Lee
- MTFCA Number: 479
Nice Set Up Ed!!!!!!!!!
- Last Name: Willams
- * REQUIRED* Type and Year of Model Ts owned: '09 Roadstr, '12 Touring, '26 Fronti Speedster
- MTFCI Number: 20566
EdL: Hi From Iowa1 I would love a set of the frt supports if available? Thanks John
- Last Name: C
- MTFCA Number: 52098
Email sent. Thanks!
Socialism is resentment disguised as compassion enforced by tyranny disguised as tolerance.
- Last Name: Morsher
Great item, Mr. Ed !
- First Name: Edmund
- Last Name: Niedzielski
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1922 Mercury Bodied Speedster, 1926-27 Roadsters /Tourings
Email sent to you Ed with my fingers crossed that I made it under the wire.
