Wanted Original 26-27 Sun Visor Corners
Topic author - Posts: 147
- First Name: Tyler
- Last Name: Prondzinski
Looking for a set of original sun visor corners for a 27 coupe.
- First Name: Tyler
Re: Wanted Original 26-27 Sun Visor Corners
Back to the top.
- First Name: Terry
- Last Name: Woods
- MTFCI Number: 20180
What part of the sun visor are you looking for? An original 26=27 sun visor frame (the part that is covered) was made up of several pieces of steel, welded together. Cupes and two doores, the same. four doors, different.
- First Name: Tyler
I'm looking for these corner brackets but an original set.
https://www.modeltford.com/item/50537FB.aspx
- First Name: Don
- Last Name: Ellis
- * REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
- MTFCA Number: 17946
- MTFCI Number: 15366
They are very easily made. they are cupped length wise for strength, but easy to make with simple tools.
- First Name: Tyler
Okay does anybody have an original set or the dimmensions of originals?
- First Name: Don
- Last Name: Ellis
I'll look at mine and get you some
- First Name: Don
- Last Name: Ellis
here's a few pictures of mine. They're not hard to make.
- First Name: Tyler
Hard to tell from the picture just how long it is? Also what is the width?
- First Name: Don
- Last Name: Ellis
6.5 “ x 5/8”. your not building a piano, it don’t have to be perfect
- First Name: Tyler
That should work, I will probably make it out of 18 or 16 gauge. Are the holes actually holes or are they slots for the tabs on the visor?
- First Name: Don
- Last Name: Ellis
Slots for the tabs that bend over
