Wanted Original 26-27 Sun Visor Corners
pron022020
First Name: Tyler
Last Name: Prondzinski
Post by pron022020 » Mon May 16, 2022 5:56 am
Looking for a set of original sun visor corners for a 27 coupe.
pron022020
First Name: Tyler
Re: Wanted Original 26-27 Sun Visor Corners
Post by pron022020 » Fri May 20, 2022 3:22 pm
Back to the top.
ModelTWoods
First Name: Terry
Last Name: Woods
MTFCI Number: 20180
Post by ModelTWoods » Tue May 24, 2022 11:26 am
What part of the sun visor are you looking for? An original 26=27 sun visor frame (the part that is covered) was made up of several pieces of steel, welded together. Cupes and two doores, the same. four doors, different.
pron022020
First Name: Tyler
Post by pron022020 » Thu May 26, 2022 8:40 am
I'm looking for these corner brackets but an original set.
https://www.modeltford.com/item/50537FB.aspx
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
MTFCA Number: 17946
MTFCI Number: 15366
Post by Don ellis » Thu May 26, 2022 9:51 am
They are very easily made. they are cupped length wise for strength, but easy to make with simple tools.
pron022020
First Name: Tyler
Post by pron022020 » Fri May 27, 2022 10:28 am
Okay does anybody have an original set or the dimmensions of originals?
Don ellis
First Name: Don
Last Name: Ellis
MTFCA Number: 17946
MTFCI Number: 15366
Post by Don ellis » Fri May 27, 2022 2:16 pm
I'll look at mine and get you some
Don ellis
First Name: Don
Last Name: Ellis
MTFCA Number: 17946
MTFCI Number: 15366
Post by Don ellis » Fri May 27, 2022 4:35 pm
here's a few pictures of mine. They're not hard to make.
pron022020
First Name: Tyler
Post by pron022020 » Fri May 27, 2022 10:37 pm
Hard to tell from the picture just how long it is? Also what is the width?
Don ellis
First Name: Don
Last Name: Ellis
MTFCA Number: 17946
MTFCI Number: 15366
Post by Don ellis » Sat May 28, 2022 6:49 pm
6.5 “ x 5/8”. your not building a piano, it don’t have to be perfect
pron022020
First Name: Tyler
Post by pron022020 » Sat May 28, 2022 11:47 pm
That should work, I will probably make it out of 18 or 16 gauge. Are the holes actually holes or are they slots for the tabs on the visor?
Don ellis
First Name: Don
Last Name: Ellis
MTFCA Number: 17946
MTFCI Number: 15366
Post by Don ellis » Sun May 29, 2022 8:15 am
Slots for the tabs that bend over
