wood coil box lid
tman12
First Name: john
Last Name: Willams
* REQUIRED* Type and Year of Model Ts owned: '09 Roadstr, '12 Touring, '26 Fronti Speedster
MTFCI Number: 20566
wood coil box lid
Post by tman12 » Mon May 16, 2022 12:25 pm
Hi From Iowa! Does anyone know where I can get a new cover made for the Hince wood coil box for my '12 T? My local wood guy was going to make one but found that he did not have the correct blade to make a perfect joint at the corners! Thanks John
Fire_chief
First Name: Charlie
Last Name: Gagel
* REQUIRED* Type and Year of Model Ts owned: 12 Tourings(2),14 Tourings(2),15 Touring,22Touring,22 TT,21 Fire Truck,14 Chief Car
MTFCA Number: 8377
MTFCI Number: 22437
Re: wood coil box lid
Post by Fire_chief » Mon May 16, 2022 2:25 pm
John Anderson, Gerry, N.Y
tman12
First Name: john
Last Name: Willams
MTFCI Number: 20566
Post by tman12 » Wed May 18, 2022 5:26 pm
Hi From Iowa! Is John Anderson RV s brother? How do I contact him? Thanks John
Fire_chief
First Name: Charlie
Last Name: Gagel
MTFCA Number: 8377
MTFCI Number: 22437
Post by Fire_chief » Wed May 18, 2022 9:06 pm
Yes he is RV's brother.
jpautowood@gmail.com
Harold
First Name: Rob
Last Name: Chatten
Post by Harold » Thu May 19, 2022 6:25 am
Hey John, You could try Mel in Ohio he does them . Or if you want to ship it Canada us Canadian could see if the same guy will do another 1 done for you . John Bell had it done for you.
Post by Allan » Thu May 19, 2022 6:46 am
I made my own, exact to the last detail, copied from an original. Then I discovered that my box was almost 1/8" wider, and the lid wouldn't fit. You need to be careful.
