Bridge Washers
Topic author - Posts: 3298
- MTFCA Number: 121
- MTFCI Number: 16310
Bridge Washers
WTB: NOS or excellent used old stock bridge washers to fit the SMALL diameter valve stems such as the 777 or 888.
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
- Board Member Since: 2013
Re: Bridge Washers
Larry, I sent you an email. I have these two Dill ones, some pitting, but if you want them let me know and I'll pop them in the mail for you, no charge. These are the only two extras that I have. Do you need any bridge washer clamp nuts or other parts before I box these up?
Re: Bridge Washers
Mark, you are a BAD man! You are tempting Original to use non genuine period pieces in places where they cannot be seen. Shame on you!
Allan from don under.
- First Name: Donald
- Last Name: Vagasky
- * REQUIRED* Type and Year of Model Ts owned: 26 Roadster 26 Touring 25TT C Cab express 26 Ames Speedster
- MTFCA Number: 10280
- MTFCI Number: 11688
Re: Bridge Washers
Yea, .......the running board step plates were bad enough.
Don
Don
- MTFCA Number: 14383
Re: Bridge Washers
This MAY not be the only non original parts being used that cant be seen.
Due to confidentiality laws I can say no more.
Re: Bridge Washers
Re: Bridge Washers
The bridge washers are on their way to Larry.
- Attachments
- red_green.jpg (16.39 KiB) Viewed 965 times
- * REQUIRED* Type and Year of Model Ts owned: '23 cutoff, '25 touring, '27 touring
- MTFCA Number: 4838
- MTFCI Number: 115
Re: Bridge Washers
Well, not quite. Seems perhaps Ford had been using Dill brand valve stems and parts at some point, sure lots of Schraders, but who knows without searching all the purchase records at the Benson Ford?
Do know Ford had purchase print (T-3413-A2) for the Dill dust covers that have the neat adjustable internal piece for the dust cap to only be twisted onto the upper valve cap threads, not all the way down a brass stem as Schrader dust caps........Allan, I know you like these!
My guess is this was 1925 for the new wire wheels, that used shorter brass valve stems too, as there was no thick felloe for the drop center wire wheels.
Re: Bridge Washers
Dang Dan! Now everybody will be after Dill covers. It makes sense that they would go with wire wheels, being adjustable for any length stem.
