WTB or trade for tire flap
RGould1910
Last Name: Gould
Post by RGould1910 » Sun May 22, 2022 4:38 pm
Looking for one 30 x 3 flap. New or good used. Will trade 30 x 3 1/2 flap or puchase outright. I see vendors sell them new but it's hard to justify almost $40 for an item that used to cost $10.
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Re: WTB or trade for tire flap
Post by speedytinc » Sun May 22, 2022 4:55 pm
You can make your own flap from an old tube. Use an old bad/repatched tube with 0$ value.
Post by Scott_Conger » Sun May 22, 2022 4:56 pm
Richard, you are a week late!!!
Lucas sent me a 30x3 flap by accident and we have arranged to return it for the 30 x 3 1/2 that was due to me. This would have been the perfect swap! Dang!!
NH Full Flow Float Valves
RGould1910
Last Name: Gould
Post by RGould1910 » Sun May 22, 2022 6:13 pm
Just my luck, Scott!
Thanks for the tip, John. If I can't find one I may give it a try. The flaps are noticeably thicker than tubes, I wonder if they protect against puncture when mounting just as well. Your thoughts, experiences, etc..
Adam
First Name: Adam
Last Name: Doleshal
MTFCA Number: 23809
MTFCI Number: 1
Post by Adam » Sun May 22, 2022 6:22 pm
A cut up old tube IS NOT the same as a flap!
First Name: john
Last Name: karvaly
MTFCA Number: 14383
Post by speedytinc » Sun May 22, 2022 7:09 pm
Better than nothing.
I would expect a bit less protection being thinner, but is does provide a layer of protection from the gap between the tire beads & gap to the bare steel rim. It will give some pinch protection & allow you to push the extra rubber(flap) & tube back in whall mounting. It will be more difficult to get a good install with a modified tube. They must be centered around the tube just as a normal flap should be.
Flaps are not a mandatory thing. They do make the job much more idiot (pinch) proof.
I used flaps on 21" wire wheels, but not on my '14. Flaps worked well on a recent 21" split rim job as well.
Post by Allan » Sun May 22, 2022 8:12 pm
The piece of old tube staying in place during fitting is not likely. A better solution is rim liner cut from the outside diameter of a 13" car tube, or from a 20" bicycle tube. These are a snap fit on the rim and will not migrate to places unwanted. Fit both beads of the tyre at the same time and the tyre levers will not get at your rube, negating the need for $40 insurance policy in the form of a heavy flap.
Hope this helps.
