Battery carrier
Topic author - Posts: 1198
- First Name: Melba
- Last Name: Nolan
- * REQUIRED* Type and Year of Model Ts owned: 23 roadster
Battery carrier
For sale. Battery carrier. Part #5150A as shown in Langs book. $40.00 plus freight.
- First Name: Daniel
- Last Name: Snell
- * REQUIRED* Type and Year of Model Ts owned: 1909 Touring, 1924 Touring, 1925 Roadster Pickup, 1921 Touring
- MTFCA Number: 31662
- MTFCI Number: 23677
- Board Member Since: 2014
Re: Battery carrier
Could you please post the measurement of the inside width (side to side) of the carrier? There is a difference between those that were used with the metal battery box. Starting sometime in 1923 the battery bracket changed to part number 5150 B to accommodate the steel battery box. Prior to that, the bracket part number was 5150 which is narrower. I have one of each the difference is about 1/4". The brackets I have seen do not have a part number on them, so to tell for sure we need that measurement. Thanks
Dan Snell
Danielsnell2@twc.com
Dan Snell
- First Name: Melba
- Last Name: Nolan
Re: Battery carrier
Its about 9 1/2 if you measure on the center bracket
- Last Name: Snell
Re: Battery carrier
The steel battery box measures 9 1/2 by 7 3/4" so the dimension side to side needs to be 8 inches to accommodate it. What is the side to side measurement?
- Last Name: Snell
Re: Battery carrier
At least it should have a width of 7 7/8 to accommodate the steel battery box. If you still have it for sale, please check this measurement, I may be interested. Thank You
Re: Battery carrier
The carrier is missing the bent outwards tabs at the top of the U shaped strap. These are needed to accept the battery hold down clamps. They can be made and welded back on. Just a heads up to avoid any disappointments.
- First Name: Melba
- Last Name: Nolan
Re: Battery carrier
thank you I didn't know that
Re: Battery carrier
- First Name: Melba
- Last Name: Nolan
Re: Battery carrier
it looks like mine has that at the end, which is different from yours
- First Name: Melba
- Last Name: Nolan
Re: Battery carrier
move to top
- First Name: Ken
- Last Name: Buhler
- MTFCA Number: 49471
- Board Member Since: 2012
Re: Battery carrier
And the bottom strap is worn through, which has to be replaced.
Work honestly
Stay true to your word
Get the job done right
- First Name: Melba
- Last Name: Nolan
Re: Battery carrier
I don't see a bottom strap
Re: Battery carrier
There are additions to the carrier as well. Ay each mounting point an extra piece has been welded in to allow the carrier to be hung from the top of the frame rail rather than bolted to the sides of the rails. I have no idea why this was done.
