WTB - MAGNETO POST
Topic author - Posts: 150
- First Name: Jim
- Last Name: Wilson
WTB - MAGNETO POST
I need a good used original magneto post for my 26 T with outside oil line. Thanks.
- MTFCA Number: 14383
Re: WTB - MAGNETO POST
There is no such thing. Original mag posts did not have an outside oil line.
- First Name: Jim
- Last Name: Wilson
Just wasn't interested in a modern repro set up.
- First Name: GG
- Last Name: Gregory
- * REQUIRED* Type and Year of Model Ts owned: 27 Roadster
My modern post with oiler looks and works every bit as good as the older reproduction. Either way, modern or early reproduction,they’re still reproductions. I wouldn’t sweat the small stuff
- MTFCA Number: 28924
For what it’s worth the older reproduction magneto oil line posts seem to be made of better materials. Or it seems that way to me.
- * REQUIRED* Type and Year of Model Ts owned: '23 cutoff, '25 touring, '27 touring
- MTFCA Number: 4838
- MTFCI Number: 115
Jim
Have one of those old time accessory posts, good condition, has old oil line attached. Best to replace the brass or copper line with new.
Can coil up the old line and fit the assembly into a small flat rate box to save $$ on shipping. Otherwise will be a long box and high shipping.
Let me know. Dan Treace email: tmodelman AT comcast DOT net. (replace with @ and . )
- First Name: craig
- Last Name: leach
- MTFCA Number: 26647
Jim,
If you are just looking for the mag contact for the modern mag post oiler I think I have one. I'm headed out there to look for something else right now.
- First Name: craig
- Last Name: leach
Like this?
Craig.-
- Last Name: Strange
- MTFCA Number: 30944
- MTFCI Number: 23667
- Board Member Since: 2013
- * REQUIRED* Type and Year of Model Ts owned: Speedster (1919 w 1926)
Original or repro ... how is the oil captured in the post to be delivered to the front bearing?
- MTFCA Number: 14972
- MTFCI Number: 15411
The oil is splash-forced into the open contact bottom.
