Found Wanted to buy radius rod ball socket for 4 dip pan Found
Topic author - Posts: 4956
- * REQUIRED* Type and Year of Model Ts owned: 1925 cutdown PU, 1920 Dodge touring, 1948 F2 Ford flat head 6 pickup 3 speed
- MTFCA Number: 52564
Found
Ok so I am going to try and straighten my 4 dip pan where the ball socket mounts. The one that is now mounted is just too bent up to mess with, along with the socket being too worn. At some time the car was hit or damaged, pushing/bending it out of shape.
I am in need of a "GOOD" socket, preferably not too worn in the ball socket. I need one that I can work from/with to get the shape close and then be able to rivet/braze back on.
1920 Dodge touring
1920 Dodge touring
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
- MTFCA Number: 27211
Re: Wanted to buy radius rod ball socket for 4 dip pan
Langs had some NOS ones at one time.
- MTFCA Number: 28924
Call Lang’s they may have one. I called them and they had some NOS tie rod parts. Mr Lang went back to look in the various boxes of NOS parts. I was glad to get them.
Thanks for the lead. I will check tomorrow.
1920 Dodge touring
1920 Dodge touring
No luck with Lang's, so back to the top.
1920 Dodge touring
1920 Dodge touring
- First Name: BOB
- Last Name: CASCISA
- MTFCA Number: 16897
- MTFCI Number: 16628
Will this work.
Looks like NOS.
Looks like NOS.
Respectfully Submitted,
Be_Zero_Be
Be_Zero_Be
- First Name: BOB
I also have this 2nd one
Be_Zero_Be
Be_Zero_Be
- First Name: Ken
- Last Name: Buhler
- MTFCA Number: 49471
- Board Member Since: 2012
Bob, I don't jump ahead of anyone. I will take #1 if Mark doesn't.
Ken
Ken
Work honestly
Stay true to your word
Get the job done right
- First Name: BOB
Ken,
You are first in line after Mark.
Be_Zero_Be
Be_Zero_Be
Bob, I will check which one I will need. Ran out and looked, approx 1 -5/8 X 3-5/8 hole spacing is the one I would need. Didn't know there was a difference. The pan was on a 1925, but who know if it was original. If check is ok, send me a pm with total and address. Thank very much.
Mark
PS sorry was later in the day when I saw this. Been outside, it is HOT upstairs were my computer is.
Mark
1920 Dodge touring
1920 Dodge touring
- First Name: BOB
Ken,
Number one is taken.
That's the only one I have.
Be_Zero_Be
Be_Zero_Be
What to give a shout out to Bob and big thank you!
1920 Dodge touring
1920 Dodge touring
